Results 1 to 9 of 9
Thread: Dashed Lines in Xref move when plotted
    100 Club sturner's Avatar
    2004-05
    Maryland (sigh)
    149
    Default Dashed Lines in Xref move when plotted
    another problem is a dashed linetype in a reference file. when i leader to it it looks fine in the drawing. but when i do a preview and plot the dashes move. so what was leadered to the center of the dash is now at the end. i have never seen this before the one solution is to bind the reference and i really do not want to do that.
    ACAD 2006 & 2009 LDD & Civil
    Windoz XP PRO(SP2)
    Debian 4.0
    2006-02
    2
    Default Re: Dashed Lines in Xref move when plotted
    I am having the same problem that you are.
    It seems like someone would be able to solve this problem.
    2001-03
    13,499
    Question Re: Dashed Lines in Xref move when plotted
    Hi
    Are the same Linetypes being used in the drawing file and the Xref file - Check system variable Measurement.
    What is PSLTScale set to ?
    Is it possible to post the drawing file and Xref file in question, so we can look at the issue / problem first-hand...
    Have a good one, Mike
    2004-05
    Maryland (sigh)
    149
    here you go mike, i zoomed into the location. note the leaders pointing to the dashed lines, than do a plot preview the dashes will move. i drew a line using the same linetype in modelspace (the white one) and this does not move?! i'm feeling it has to do with the refrence but have run out of ideas... thanks for taking the time to look at this Mike.
    ltscale =1
    psltscale =1
    plinegen=on
    Windoz XP PRO(SP2)
    Debian 4.0
    2001-03
    13,499
    Quote Originally Posted by sturner
    ltscale =1
    psltscale =1
    plinegen=on
    Hi
    Is there meant to be an attachment with the above post ?
    If yes, could you please try again.
    If no, could you please post the drawing file and Xref file in question, so we can look at the issue / problem first-hand...
    2004-05
    Maryland (sigh)
    149
    oops! must of been distracted
    Windoz XP PRO(SP2)
    Debian 4.0
    2001-03
    13,499
    Hi
    No worries...
    Ok! I will take a further look at the issue / problem tomorrow ( Is now 01:25 AM here, I need to catch a few ZZZ's ).
    Just so I know I am looking at the correct area...
    * Open drawing file 12913-Wet Permits22.dwg
    * Looking at Layer BE-WETLAND-NONTIDAL-BUFFER-25 ( Linetype - Dashed 3 ) belonging to Xref file 12913-XCOND.dwg
    * Leader and MText ( contents NON-TIDAL WETLAND BUFFER ) on Layer TEXT.
    Have I got the above correct ?
    2004-05
    Maryland (sigh)
    149
    Quote Originally Posted by Mike.Perry
    Hi
    No worries...
    yes sir,
    thanks!
    Windoz XP PRO(SP2)
    Debian 4.0
    2001-03
    13,499
    yes sir,
    thanks!
    Hi
    I almost forgot about this thread. Sorry.
    I have not yet! found a satisfactory answer / solution
    So far...
    * Dashed Linetype ( Dashed3 ) moves / shifts in Plot Preview when Object is a Polyline and uses a Custom Dashed Linetype.
    * If Object type Polyline uses a Standard Dashed Linetype ( Dashed / Dashed2 / Hidden / etc ), it does not exhibit the move / shift problem..
    * Object type Line is not affected, regardless of Dashed Linetype used ( Standard or Custom ).
    * Using a Custom Dashed Linetype associated with a Polyline Object, I have had mixed results when playing about with PLineType ( set to 0 ) and_or ViewTwist.
    The issue / problem appears ( to me anyway ) to be related to Polylines that use Custom Dashed Linetypes.
    PLineType ( set to 0 ) and_or ViewTwist might also have something to do with it, but like I said above, so far I have experienced mixed results when playing about with those options.
    If I have more time, I will take a further look.
  1. hidden lines showing as dashed lines
    By tomcarver in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-09-26, 09:09 AM
  2. ADT 2007 - Text within Xref moves when plotted
    By .chad in forum ACA General
    Last Post: 2007-01-18, 10:26 PM
  3. Dashes in custom linetype move when Plotted
    By bryanf in forum AutoCAD General
    Last Post: 2006-08-03, 04:59 PM
  4. Help With Dashed Lines
    By sean.78805 in forum AutoCAD LT - General
    Last Post: 2004-12-05, 11:32 PM
  5. Dashed lines not dashed in Layout view
    By pford in forum AutoCAD General
    Last Post: 2004-06-15, 07:54 AM
