Results 1 to 10 of 15
Thread: Underlay Behavior EXPLAINED
    100 Club mschroeder's Avatar
    Boston
    154
    Post Underlay Behavior EXPLAINED
    If you have ever wondered why some walls don't show up in underlays or show up inconsistently from floor to floor, or why roofs and view ranges affect their behavior, then read on.
    First rule of underlays: Underlay view extent properties (cut, range, depth) are not user modifiable and not coupled to any other view's properties.
    For "Plan orientation" underlays:
    The cut plane of the underlay is always taken at the level above the selected underlay level and looks down to the selected underlay level.
    If you try to underlay the highest level then the underlay cut plane is set infinitely above the top level.
    "Reflected Ceiling Plan" orientation:
    The cut plane of an underlay is set to the selected underlay level and looks up to the level above the selected underlays level.
    It's also been mentioned "If objects are visible in the view range of your current view, AND in the view range of your Underlay, they are automatically hidden in your underlay, so there isnt a double instance."
    I can find no evidence of this. Instead, the object's line style switches from an override state to normal object style when the object is within the view range.
    I hope some of you find this useful.
    Certifiable AUGI Addict twiceroadsfool's Avatar
    2006-01
    4,516
    Default Re: Underlay Behavior EXPLAINED
    Quote Originally Posted by mschroeder
    This occured on one of our roof plans, which prompted my searching for it. thats why i mentioned it yesterday.
    We have a roof plan with a cut plane of 45' (first floor plan) and a bottom and view depth of 10' (first floor plan).
    If you underlay the First Floor Plan, (cut plan of 4' (first floor plan), top of 8' (first floor plan) , the walls on the first floor plan will NOT show up for us.
    They are taller than 10 feet, so they show up in both view ranges. The underlay will be missing all of those walls.
    Boston
    154
    Quote Originally Posted by twiceroadsfool
    Can you post an example?
    2006-01
    4,516
    See the attached. The three walls that are visible in the underlay are ONLY visible in the View range of the First floor plan (the underlay). The View range of the roof plan itself does not extend down that far, so it will display the information in the underlay.
    The other three interior walls show up in BOTH view ranges. Becayse theyre already *visible* in the roof plan, they will not display in the underlay. If you edit the roof plans view range so it doesnt go down to intersect those walls (put it at 3' below the roof plan) then youll notice that they suddenly show up in the underlay, because they are now not *visible* in the roof plans view range.
    Yesyes?
    Boston
    154
    underlay..
    These walls are just obscured by your roof (temporary hide the roof and see what I mean)
    Right, but let me reiterate "the object's line style switches from an override state to normal object style when the object is within the view range." Revit does not hide anything from you.
    2006-01
    4,516
    Um, youre not getting what im saying...
    If i wanted to see the walls by hiding the roof, i wouldnt be using an underlay at all. The whole point is to work on the roof WHILE looking at whats below. While it may change the line styles, it DOES remove those walls from the underlay.
    If you hide the roof, you arent seeing walls in the underlay, youre seeing walls in the actual view. For instance:
    In the attached file, the exact conditions i presented before are present, except there is now a floor at the third level. So temporarily hide the roof: The three walls that are *in both view ranges* STILL dont show up in the underlay, and now that the floor is in the way you cant see them.
    Boston
    154
    We're going in circles. Believe me, I've had Autodesk clarify this through support requests, and even though this feature is working as programmed, they understand the confusion and have submitted it for enhancement.
    No sense in beating a dead dog - I thought that a concise description (It's not covered well in Revit's help) of the underlay behavior would help some people understand why certain things don't show up, which is why I submitted it to the forum in the first place.
    2006-01
    4,516
    Understandably so. Likewise, im trying to clarify for people who have the same mishap with their underlays, that items in their underlays WILL disappear depending on the view range of the view they are putting the underlay in, and the objects in the underlay themselves.
    I too have had this clarified:
    http://usa.autodesk.com/adsk/servlet...linkID=3770375
    Quoted from Autodesk: Issue
    When you tried to underlay a floor, only doors and windows were visible.
    Solution
    This issue occurs because there is an incorrect view range in the main view. If the view range intersects the geometry of a level in your main view, that level cannot be used as an underlay in the main view.
    For example:
    In the main floor level, the bottom of the primary range is set to main floor with an offset of -1’-0” and/or the View Depth has similar settings. The level below will not be an option for an underlay because it is already part of the primary view.
    To correct this issue, you will need to reset these values to have no offset.
    So for people who need view depths set extremely to achieve their goals (such as a roof plan that reachs down almost to the ground plane), then their underlays will have items removed, as i said in my first post.
    Count (Formula) dbaldacchino's Avatar
    2005-07
    Missouri City, Texas (Houston area)
    3,250
    Question Re: Underlay Behavior EXPLAINED
    This doesn't seem to be the case and I'm still struggling to figure out what's the logic that Revit is using to display an underlay. See attached file. I have an underlay set to level 3. Per your explanation, the underlay cut plane should be at level 4 looking down on to level 3. So in theory, my underlay should look like Level 4 plan in the example (I set the cut plane here to have a 0 offset). But when I underlay Level 3 in Level 1, I get a roof plan view with nothing being cut. Why?
    2003-12
    Palestine
    51
    I would expect an underlay be used to show overhead elements - beams, canopies, etc. Unfortunatly this is not the case. Beyond what's being mentioned I suppose there is a place for improvement where visibility control (both visibility of elements and individual view range control) be set for the underlay (underlayed ceiling plan for example) individually to show only certain elements and specifying linetypes for these elements. I wonder how others are dealing with the issue of overhead elements other than simply drafting lines.
  1. LayoutTools Explained
    By irneb in forum AutoLISP
    Last Post: 2010-04-17, 10:35 AM
  2. THE JOURNAL FILE EXPLAINED!!
    By ykang in forum Revit Architecture - General
    Last Post: 2007-05-03, 01:14 PM
  3. WORKSETS EXPLAINED!!!
    By ykang in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2007-02-04, 04:03 AM
