Results 1 to 10 of 10
Thread: Keyboard Short-cuts / Tips
    100 Club sturner's Avatar
    2004-05
    Maryland (sigh)
    149
    Default Keyboard Short-cuts / Tips
    here are a few for the keyboard lover in all of us!
    If you type ‘EXPLORER’ in the AutoCAD command line it will open windows explorer.
    While in paper (layout) space typing ‘MS’ or ‘PS’ will drop you into or out of a viewport.
    Ctrl + R = cycle thru viewports
    Hold down the ctrl + tab and cycle thru your layouts
    Alt + tab = cycle thru active windows
    Ctrl + S = quick save
    Ctrl + Q = quit
    Ctrl + O = opens a drawing
    Ctrl + N = starts a new drawing
    Ctrl + P = starts the plot dialog
    Using the up or down arrow keys will scroll thru recently used commands
    Holding down the shift key will unselect objects
    Using ‘U’(undo) will work in most commands.
    ACAD 2006 & 2009 LDD & Civil
    Windoz XP PRO(SP2)
    Debian 4.0
    2001-03
    13,499
    Default Re: Keyboard Short-cuts / Tips
    Hi
    HERE'S a few more...
    Have a good one, Mike
    Member findamega's Avatar
    2006-06
    2
    Wink Re: Keyboard Short-cuts / Tips
    if you want to hide command line window just press >> ctrl+9
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    548
    Quote Originally Posted by sturner
    I think Ctrl + Tab cycles thru open documents and not layouts. I believe this is a windows standard keyboard shotcut that goes along with Ctrl+C (Copy), Ctrl+X(Cut), Ctrl+Z(Undo) and Ctrl+V(Paste), which most MS Windows programs uses.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    0,0,0 The Origin
    8,027
    Quote Originally Posted by arshiel88
    True.
    Ctrl + PageUp/PageDown takes you through the layouts.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2005-02
    Off the Grid
    548
    Quote Originally Posted by jaberwok
    True.
    Honestly, I don't know this keyboard shortcut. I tried PageUp and PageDown and it doesn't work. Ctrl+PageDown/PageUp does.
    Shielbern Bolalin
    1879-1955
    0,0,0 The Origin
    8,027
    Sorry, typing too fast.
    Previous post edited.
    John B
    2005-11
    6
    I did not know about this one, but i will certainly use it from now on.
    I think his is great.
    Thank you.
    2007-05
    Cool Re: Keyboard Short-cuts / Tips
    You can also create an alias for EXPLORER and more through the command alias editor in the express menu. Select the Shell Commands tab in the dialogue box, then add your alias, I use WX (windows explorer)
    An easy shortcut to open drawings on a network is, when you reach the folder where the drawing is, before you open the drawing, move the cursor to the "look in" panel to the left. Right click and select Add Current Folder. It now adds the folder. You can then right click the folder to rename it if you want You can add and delete folders as required. I find this very useful when working on multiple projects.
    2005-02
    Off the Grid
    548
    Quote Originally Posted by dbentz.138845 View Post
    You can also create an alias for EXPLORER and more through the command alias editor in the express menu. Select the Shell Commands tab in the dialogue box, then add your alias, I use WX (windows explorer).
    Isn't it easier to press the [Windows Logo key]+E than typing "WX" then space bar? ...Unless you don't have the Windows logo key.
    Shielbern Bolalin
    1879-1955
  1. Keyboard shortcuts - tips and tricks
    By rtaube in forum Revit Architecture - General
    Last Post: 2010-07-20, 02:17 PM
  2. Built In Short Cuts
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2009-06-26, 04:40 AM
  3. how do I change keyboard short cuts?
    By cobra1964 in forum AutoCAD Tips & Tricks
    Last Post: 2008-01-11, 05:24 PM
  4. Keyboard Short Commands
    By lureguy in forum AutoCAD CUI Menus
    Last Post: 2007-10-18, 08:58 PM
  5. Keyboard short-cuts
    By m.storey in forum AutoCAD Customization
    Last Post: 2004-11-03, 03:59 PM
