Thread: Folder or List
    2002-11
    2
    Unhappy Folder or List
    We have just moved up to AutoCAD 2004 from 14. After working on AutoCAD for a month,
    I now find that whenever I try to open a new drawing, the dialog box has defaulted to FOLDER view. I find that the FOLDER view takes more time to generate. If I pick LIST, the dialog box changes to LIST but if I go to another directory, the FOLDER is back. How do I set the open dialog box to default to LIST mode???
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    Default Re: Folder or List
    What os do you have?
    C:> ED WORKING....
    2002-11
    2
    Arrow Re: Folder or List
    We are using Microsoft Windows XP Professional.
    Turlock, CA
    4,776
    Open Explorer and click on Tools>Folder Options>View tab. Make sure that "Remember each folder's view settings" is checked.
    C:> ED WORKING....
    2001-03
    13,499
    Hi
    Just to complement Ed's correct answer, check out the following threads -
    Open Dialog Box
    Open Drawing - View in XP - I want DETAILS
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS71052 - Retain View setting in Open dialog box between AutoCAD® sessions
    Have a good one, Mike
  1. Replies: 0
    Last Post: 2011-05-30, 07:07 AM
  2. LIST Command doesn't list Attached by Layer Materials
    By rbdome in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-01-18, 01:15 AM
  3. Replies: 8
    Last Post: 2006-12-27, 01:05 PM
  4. Folder naming and allowable characters in folder names
    By fletch97 in forum CAD Management - General
    Last Post: 2006-10-26, 06:01 AM
