I created a curtain wall panel family that consists of an extrusion with a parametric void at the top. The reveals in the panel are also void extrusions with parameters for the bottom reveal height and the distance between the remaining ones.
The panel flexes well in the family file, but when it is loaded in the project and used it as a curtain wall panel in the project, the extrusion doesn't get to the end of the panel.
Can anyone explain why the void extrusion doesn't work the same way in the curtain wall as it did when I created it in the curtain wall panel family? I suspected the curved curtain wall might be to blame, but had the same behavior with a straight curtain wall.
To get the reveal to extend the width of the panel, I've had to add a parameter for the reveal width and crank it up to about 3600.
Attached is the family file and a project with the wall in question.
Any suggestions?
