Results 1 to 10 of 13
Thread: Keyboard speed (quick keys) in AutoCAD 2007
    100 Club andrewp's Avatar
    2003-06
    149
    Question Keyboard speed (quick keys) in AutoCAD 2007
    Okay guys… here’s one for ya… I use my right hand to mouse with and my left to key-in quick keys… the issue is in AutoCAD 2007… I can type “co” (copy) and start to place a circle… or “ex” (extend) erases the object… or “tr” (trim) allows me to start a text command… I think you get the picture…
    I have no problem with the reaction time between the key-in and the command in AutoCAD 2002… is there a setting that controls the sensitivity or speed of the key-in’s for AutoCAD 2007? Or do I need to slow down, which kind of defeats the purpose for quick keys, doesn’t it?
    Any ideas? Thanks...
    Earth
    9,805
    Default Re: Keyboard speed (quick keys) in AutoCAD 2007
    Do you have dynamic input enabled? If so, disable it (DYNMODE = 0).
    IMO - this should have been disabled by default....
    R.K. McSwain | CAD Panacea |
    2001-12
    St. Louis
    5,407
    Question Re: Keyboard speed (quick keys) in AutoCAD 2007
    Is dyn input really that slow in 2007? I haven't had a problem in 2006. (I love Dynamic Input, and I'd hate to have to turn it off when I upgrade to 2007 )
    Quote Originally Posted by rkmcswain
    Melanie Stone
    @MistresDorkness
    Technical Editor
    13,656
    Quote Originally Posted by Wanderer
    Hi
    Some people have reported such issues / problems, take a look HERE.
    Have a good one, Mike
    I could stop if I wanted to Steve Johnson's Avatar
    2004-11
    Western Australia
    294
    You probably won't notice any difference between this in 2006 and 2007. If it's fast enough for you now, it will probably be fast enough for you in 2007. For me, it's unusably slow in both releases, and its failure to echo at the command line is a fatal ergonomic flaw.
    Earth
    9,805
    2006 and 2007 are equally slow with DYNMODE enabled. The OP said he was coming from 2002 (no DYN) though.
    2003-06
    149
    just an observation but, i've found that when the command input is not near the crosshairs, it's tons faster... but, i can't figure out why it's not showing the crosshair command input because i have it toggled on... it just quick working... weird, huh?
    i will let you know if i figure it out... thanks for the help...
    2001-12
    Estepona. Spain
    34
    It's possible to need change variable TEMPOVERRIDES?
    Excuse my poor english.
    Mateo.
    2004-07
    Baton Rouge, Louisiana
    254
    its also possible for the acad.pgp file to be messed up. if you are getting a circle for for the quick key input. if you do like we do and some of autocad's commands and support files on a server and someone may access it and mess it up, it happened to us. thankfully it was and easy fix
    2003-06
    149
    TEMPOVERRIDES doesn't seem to make a difference.
  1. Methods of adding custom labels to keyboard keys I have customized within AutoCAD
    By robert.1.hall72202 in forum AutoCAD Customization
    Last Post: 2007-02-15, 01:39 PM
  2. AutoCAD 2002 - Function / Tool that edits AutoCAD command quick keys
    By stevejlipski in forum AutoCAD Customization
    Last Post: 2007-01-02, 12:07 AM
  3. AutoCAD 2006 Keyboard Shortcuts assigned to Function keys
    By YKBELL in forum AutoCAD CUI Menus
    Last Post: 2006-11-02, 04:42 PM
  4. AutoCAD 2006 - Quick / Short-cut keys are not working
    By jlizann in forum AutoCAD General
    Last Post: 2006-06-24, 03:04 AM
  5. Replies: 9
    Last Post: 2006-05-12, 01:23 PM
