Results 1 to 10 of 10
Thread: Display list of Xrefs in a Field via LISP
    2004-08
    19
    Default Display list of Xrefs in a Field via LISP
    I just read an article in AUGIWORLD about combining AutoLisp & Fields. Does anyone know of a way to use a field to show the x-refs attached to a dwg?
    Chris
    Earth
    9,805
    Default Re: Display list of Xrefs in a Field via LISP
    No, but this is one thing that the old RTEXT can still do.
    Example: $(xrefs,3)
    See the ET help file (\Express\acet.chm) for more details.
    R.K. McSwain | CAD Panacea |
    2005-08
    1,043
    I don't know about fields, but I do know how to get a list of xrefs.
    (defun XrefList (Doc / Lst)
    (vlax-for Blk (vla-get-Blocks Doc)
     (if (equal (vla-get-IsXref Blk) :vlax-true)
      (setq Lst (cons (vla-get-Name Blk) Lst))
    Lst
    Called like (for current drawing)
    (XrefList (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    Must have loaded
    (vl-load-com)
    into the drawing at least once before you can use this.
    Earth
    9,805
    I bet he was inquiring about using a FIELD because he wants a string that updates automatically. Although RTEXT has it's other limitations, it does update automatically, compared to having to run the lisp code each time.
    2004-08
    19
    Correct. In the meantime will have to look into RTEXT. Thanks for the help.
    2005-08
    1,043
    You could use reactors then once the text in the drawing, to update it. Just another idea.
    2004-08
    19
    I can't figure out why this isn't working:
    MTEXT. Insert field. Add Diesel Expression (or something like that). I type $(xrefs,2). Ok.
    The result is $(XREFS)??
    I tried saving the dwg. I closed & reopened the dwg. I had one x-ref already in the dwg, but I added a couple more just in case, but the field doesn't show the x-refs.
    Can anyone tell what I'm doing wrong?
    Thanks a lot.
    Earth
    9,805
    Quote Originally Posted by crohloff.72988
    Thanks a lot.
    Please re-read my original reply.
    $(xrefs,2)
    is not a DIESEL string and it doesn't work in a FIELD.
    That is special syntax that only RTEXT recognizes.
    2004-08
    19
    Thanks RK. What was throwing me off is that in ET Help it does refer to $(xrefs) as a DIESEL function. However, for another function, $(getprop), it says it is supported only in RText objects. Apparently the same is true for $(xrefs).
    I could stop if I wanted to Hammer.John.J's Avatar
    2015-09
    Springfield, MA
    491
    there seems to be a limit on the number of characters rtext will dislplay... so be aware not all of your xrefs may display, i ended deleting this part of our tag because of that
  1. Fields dispaly as # - xrefs and field categories
    By jkipfer in forum AutoCAD Fields
    Last Post: 2007-11-07, 03:36 PM
  2. Replies: 3
    Last Post: 2007-07-11, 06:13 PM
  3. Replies: 2
    Last Post: 2007-04-20, 05:40 AM
  4. List Xrefs in Field
    By red2002yzfr1 in forum AutoCAD Fields
    Last Post: 2006-08-04, 01:43 PM
  5. Field to list all XREFs in a drawing
    Last Post: 2006-03-13, 12:44 AM
