Results 1 to 10 of 11
Thread: Double-clicking on DWG files - What application do you want to use...
    2004-08
    19
    Default Double-clicking on DWG files - What application do you want to use...
    Since our last AutoCAD upgrade, double-clicking on a .dwg file in Windows results in a "What application do you want to use..." type message. However, if I have AutoCAD running and double-click on a file, it will open as it should. A co-worker suggested changing something in the registry, but that's a little over my head. Has anyone had any experience with this?
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,257
    Question Re: Double-clicking on DWG files - What application do you want to use...
    Quote Originally Posted by crohloff.72988
    Please share your version of autocad and windows so that you can get the most accurate answer, and I can move this post to the best location.
    Thank you.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    I could stop if I wanted to SRBalliet's Avatar
    2004-06
    In a loghouse, Looking for a job!
    495
    Default Re: Double-clicking on DWG files - What application do you want to use...
    Right click on a dwg file
    pick "Open With"
    pick "Choose Program"
    pick "AutoCAD" from the list
    check "Always use this program to open these files"
    Steve Balliet
    Craig Co., VA
    Civil 3D & Land Desktop 2008, Mechanical 2009
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    Do not open Autocad from windows explorer, it can have devastating effects. I have had multiple instances were it caused me to totally remove every hint of AutoCAD from a machine and do a complete install. Each time I have had to do this it was after someone tried to open a drawing from window explorer. It only takes a few additional seconds to open a drawing from within acad and it is worth the time if you trash your install.
    All AUGI, all the time Avatart's Avatar
    2004-06
    here, watcha gonna do?
    926
    Quote Originally Posted by charlieb
    I have never, in 23 years of using AutoCad, had a problem opening a drawing of such magnitude that it required a reinstall. Do you have other software that can open the DWG filetype?
    ^^ Ceci n'est pas une post ^^
    2004-06
    495
    99% of the time I open my drawings from AutoCAD, but there are others in the office who do it by double clicking a file all the time. We have never had a meltdown. But, as they say better safe than sorry.
    Steve Balliet
    Craig Co., VA
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,277
    I've never had a problem using Windows Explorer to open an AutoCAD file, but I am trying to move away from that... PowerDesk is so easy though!
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2004-08
    19
    Sorry for the lack of info in my original post. I'm using AutoCAD 2005 & Windows XP.
    The funny thing is - when I do the "right-click -> Open with" I am not even given AutoCAD as an option. Even browsing to it doesn't seem to work.
    Personally, this whole thing isn't an issue for me. I usually have AutoCAD running all the time anyway, and when I do double-clicking in Windows works. An engineer & another CAD tech brought it up to me, so I was hoping there was an easy fix. Personally, I'd rather not have to go into the registry on every user's computer.
    Also, I've never experienced the disaster that charlieb mentioned in his post.
    Thanks for the help.
    0,0,0 The Origin
    8,027
    There have been many tales of woe about opening dwg files from Explorer but I haven't heard of any new tales since around the launch of Win2k and few, if any, of the earlier stories were (to me) fully verifiable.
    Still, I open files from acad.
    1. I've been using it since v2.5 and the same comments apply as for R9 but for longer.
    2. Better safe than sorry.
    3. I have a shortcut to acad in my startup folder so acad is always ready.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2001-12
    St. Louis
    4,257
    Talking Re: Double-clicking on DWG files - What application do you want to use...
    No worries. I'll go ahead and move this post from the CAD Management General Forum to this one, as I believe it will be better served here. Thank you.
    Technical Editor
  1. Double clicking to edit text - where are you?
    By Rico in forum AutoCAD General
    Last Post: 2006-12-18, 02:31 PM
  2. I want to edit a Block in place by double clicking on it
    By pangell in forum AutoCAD General
    Last Post: 2006-06-07, 11:18 AM
  3. Lost Double Clicking ability... Please help
    By jared.84927 in forum AutoCAD General
    Last Post: 2006-03-06, 06:31 PM
  4. Double clicking to edit (attedit) not working
    By cmason in forum AutoCAD General
    Last Post: 2006-01-04, 03:45 PM
  5. Default to 8.1 when double-clicking an RVT file
    By J. Grouchy in forum Revit Architecture - General
    Last Post: 2005-10-16, 02:19 AM
