Thread: Alert message does not display in while statement
    2003-11
    277
    Default Alert message does not display in while statement
    Hi Alls,
    I have a simple code to check if a variable same as a target,then alert message would display,I just repeat test it,but always fail,any am I wrong?
    (defun c:test (/ sdia hei)
      (setq sdia 25)
      (setq hei 21)
      (while
        (if
          (= hei (* sdia 0.8))
          (alert "\nTarget has finish")
          )                                              ; if
        (setq hei (- hei 0.1))
        )                                                ; while
      )                                                  ; defun
    Active Member ElpanovEvgeniy's Avatar
    2006-09
    Russia, Moscow
    54
    Default Re: Alert message does not display in while statement
      (setq sdia 25)
      (setq hei 21)
      (while (if (equal hei (* sdia 0.8) 0.01)
             ) ; if
      ) ; while
    All AUGI, all the time CAB2k's Avatar
    2002-12
    Brandon, Florida
    687
      (setq sdia 25)
      (setq hei 21)
      (while (> hei (* sdia 0.8))
    2003-11
    277
    Hi elpanov,
    It's great,many thanks for you.
    Quote Originally Posted by elpanov
      (setq sdia 25)
      (setq hei 21)
             ) ; if
      ) ; while
  1. Display Z Coordinate in an Alert Box?
    By vsheehan in forum AutoLISP
    Last Post: 2011-07-14, 06:54 PM
  2. Alert message box is suppressed
    By Tharwat in forum AutoLISP
    Last Post: 2010-07-12, 06:49 PM
  3. Replies: 5
    Last Post: 2008-11-20, 04:48 PM
  4. DB alert message
    By cwjean76 in forum Dynamic Blocks - Technical
    Last Post: 2008-03-26, 06:11 PM
  5. Display Error Message
    By kjgiant in forum Revit Architecture - General
    Last Post: 2004-11-03, 08:51 PM
