View Poll Results: How do you open your drawings?
Voters
43. You may not vote on this poll
  • Within AutoCAD (or Vertical)?
    17 39.53%
  • From Windows Explorer?
    6 13.95%
  • Both?
    19 44.19%
  • Other?
    1 2.33%
Results 1 to 9 of 9
Thread: Where do you open your drawings from?
    2004-06
    198
    Default Where do you open your drawings from?
    I saw a response to a previous question and was wondering if how people open their drawings reflects what version of AutoCAD or Windows they started using the softeare with?
    Foe me I started with R9 in school and only had the option to open drawings from the command line. I think that is why I open my drawings from AutoCAD and not the windows explorer.
    All AUGI, all the time Avatart's Avatar
    2004-06
    here, watcha gonna do?
    926
    Default Re: Where do you open your drawings from?
    I remember from the early DoS versions, opening from the DoS prompt and closing AutoCad before opening another drawing, what a pain that was! Now I tend to open single drawings from within AutoCad or lots of drawings from Explorer. I also use our Batch Manager quite a lot to run scripts on files, does that count as an opening method? There is also the open from Xref manager option and RefEdit is a kind of open.
    ^^ Ceci n'est pas une post ^^
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,233
    Quote Originally Posted by StephenJ
    I also cut my teeth on r9 and do recall trying to open drawings there. Oye! At the company I was at before here we opened drawings from Windows Explorer almost exclusively. Here, now, I've gotten in the habit of opening drawings from within ACAD. Lately, I've been more and more in the practice of using Sheet Set Manager for opening existing drawings.
    AutoCAD Civil3D 2013
    Gig 'Em, Aggies!
    Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,273
    I try to open my drawings from ACAD, but I'm used to using PowerDesk, and with the ability to keep two folders open at once, it really helps when working with multiple projects.
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    I open my drawings from within AutoCAD. I used to use explorer alot but found that being impatient I would inadvertently try to open a second drawing while the first was still opening which would cause Autocad to want to cache in excess of 500 megs and more of memory before starting, and the initial amount of memory needed would gradually increase to over a gig. This had happened on several machine in my group, the response from Autodesk was to only start a drawing from within AutoCAD.
    Active Member david-k's Avatar
    2002-11
    San Diego, CA
    78
    Exclusively from within Autocad.
    Especially after using the "recent.vlx" available fro DotSoft allowing choosing from a listing of many more recent drawings opened than the default. This is helpful with LDT3.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    I am trying to train myself to open drawings from a folder containing sheet sets.
    Really tough to teach a cad wiz some new tricks. I have the folder docked to the
    windows taskbar and seldom use it to open drawings.
    2006-01
    Land of chocolate
    228
    depends on the situation - i find myself alot seeking with explorer and draggin them into ac
    Certified BIM Addict Brian Myers's Avatar
    2003-02
    Working in Cyberspace
    1,682
    It depends. Typically my first drawing I open by searching and clicking (in a program very similar to a more robust Windows Explorer) then after that I open them from AutoCAD.
    Brian Myers
    Sr Applications Engineer, Seiler Instrument | Autodesk Certified Instructor (ACI) Revit Architecture
    Creator of the Revit Users LinkedIn Community | Author of Revit Videos @ Lynda.com
  1. Replies: 2
    Last Post: 2011-04-28, 02:04 AM
  2. Open Drawings
    By JeffClark in forum AutoCAD General
    Last Post: 2010-08-10, 03:56 PM
  3. I'm limited to only 3 drawings open.
    By kb3cxe in forum AutoCAD General
    Last Post: 2006-04-02, 12:39 AM
  4. Can't open drawings
    By tammy346 in forum AutoCAD General
    Last Post: 2004-09-30, 11:11 PM
  5. Cannot Open certain drawings
    By vincentfresco in forum AutoCAD General
    Last Post: 2004-08-06, 10:25 PM
