Results 1 to 6 of 6
Thread: Concrete encased structural steel beam
    2006-04
    21
    Default Concrete encased structural steel beam
    I need to make a structural steel beam encased in concrete. I made a new family and it looked right, but when I loaded into the project the concrete disappeared.
    Any suggestions?
    Thanks
    Pinky
    Last edited by pinky; 2006-09-21 at 11:12 PM. Reason: addition of file so people can see
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Default Re: Concrete encased structural steel beam
    try posting the family. you will probably get a lot more responces if people have something to look at.
    Justin
    2006-04
    21
    I have loaded the family as an attachment so any help will be appreciated.
    I could stop if I wanted to sleimgruber06's Avatar
    2005-12
    Workin' & Playin' in Beautiful Southern California
    259
    I do not see the attachment...where is it
    *Edit*
    LOL Nevermind, I must open my eyes every once and awhile...I found it...
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    Nest the steel component as a detail component within the concrete beam family. Here is a typical example
    As a nested detail component, it will be visible in any cross section thru' the beam.
    2006-04
    21
    Thank you very much. I am still learning about nesting objects so this helps to understand. Thanks again
  1. 2012: Concrete Encased Steel Beams
    By Jay North in forum Revit Structure - General
    Last Post: 2012-03-26, 05:51 PM
  2. Concrete wrapped steel beam family
    By mthurnauer in forum Revit Architecture - General
    Last Post: 2010-07-15, 06:33 PM
  3. Concrete encased steel brace ...
    By Mike hacker in forum Revit Structure - General
    Last Post: 2007-05-26, 12:00 AM
  4. Concrete encased structural steel beam
    By pinky in forum Revit Architecture - Families
    Last Post: 2006-09-21, 10:25 PM
  5. Concrete Encased Steel Columns?
    By ekneer in forum Revit Structure - General
    Last Post: 2006-04-04, 04:30 PM
