Thread: Custom Menu in 2004
    2004-06
    10
    Question Custom Menu in 2004
    Has anyone ever seen an issue where the menuload dialog box doesn’t respond when you hit ‘load’?
    My user is on XP pro, and several different menus are giving him trouble. My machine is 2000 pro, and I’m having no trouble.
    Thanks in advance
    40
    Default Re: Custom Menu in 2004
    Yes.
    I have two versions of a custom mns file on the system. One loads. The other does not load when I browse for it and hit load in the menuload dialog box. The one that does not load is an incomplete/corrupted file. Check the content of the menu file you are trying to load.
    2004-06
    10
    Nothing yet. This is a frustrating one.
    I'll post if I find anything.
  1. 2004 to 2008 Custom Menu's not there
    By GreenMan415 in forum CAD Management - General
    Last Post: 2007-10-12, 06:58 PM
  2. ADT 2004 menu question
    By CADMama in forum AutoCAD CUI Menus
    Last Post: 2007-10-11, 03:38 PM
  3. Adding custom Pop Menu via code to the menu bar.
    By dfe in forum AutoCAD CUI Menus
    Last Post: 2006-10-20, 01:36 PM
  4. Load a custom menu into a custom CUI
    By jeff.garr in forum AutoCAD CUI Menus
    Last Post: 2006-06-16, 03:26 PM
