Thread: Apply line object data field to linetype?
    2000-10
    59
    Thumbs down Apply line object data field to linetype?
    Anybody know if there is a quick and dirty way to read the value of an object data field an apply a linetype accordingly? Example, I am importing ESRI .SHP files for water lines that have a field for the pipe size, I have linetypes for various pipe sizes i.e. "water8" for "8" Water".
    If it's not quick and dirty, it's not worth the effort, I can just annotate the line with the value, but the linetype would clean it up a little for me.
    Bruce
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,446
    Lightbulb Re: Apply line object data field to linetype?
    Possibly create a Lookup table for the linetypes? They would need to be defined in the drawing before running the Import though. Might take two steps instead of automatically updating as the linework comes in, but it may be a bit faster of an option.
    2004-06
    19
    Default Re: Apply line object data field to linetype?
    Hi,
    Possibly post a piece of dwg or
    Table Name:
    Field name:
    Field Type:
    Give the details I can prepare a routine to do your request.
    Best Regards,
    Prabhakar.B
    bprabhakar001@gmail.com
    2000-10
    59
    Wow! Thanks for the quick responses and help, I will try both methods. I have attached a small piece of the drawing.
    Bruce
    TN/KY Area
    1,640
    Use linetypes by layer then when you import create the lines on the layer obtained from the data. Another option is do a property query to change the line type after you import.
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. linking field data to other object data
    By keith_velishek in forum AutoLISP
    Last Post: 2014-03-23, 03:53 AM
  3. Command line interface for MEP object data
    By RobertB in forum AMEP General
    Last Post: 2009-07-24, 04:11 PM
  4. Field data lost at data link synchronization
    By brennsvette in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-09-17, 03:07 PM
  5. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
