Is there any way to add a Parameter to The System Family: Project Information
Example:
Project Due Dat
Example:
Project Due Dat
Not for sure if this is what you are looking for but, have you looked at "Project Parameters..." located 2nd down int the "Settings" pull down? Add a new parameter and assign it to the categories of choice.
jamie
jrichardson is correct.
Go to Settings -> Project Parameters
Press 'Add...'
Under Categories check 'Project Information'
You probably want to set parameter type to 'Shared parameter' (I don't know what exactly you intend to do with the parameter...)
You should be pretty much set.
