Results 1 to 10 of 18
Thread: Different scales for lines in different viewports
    2003-12
    5
    Red face Different scales for lines in different viewports
    I have a dwg that has multiple viewports. In some viewports the linetype needs to be at a 20 scale, in others I need the lines to be a 30 scale. I think this is possible because I seem to remember even doing it, but I can't figure it out now. Can anyone help me?
    Suzy Laidlaw
    100 Club jhohman's Avatar
    2003-08
    Spring Hill, Florida
    195
    Lightbulb Re: Different scales for lines in different viewports
    I would simply select the lines that you want to be at a LTSCALE of 20 and set that scale in the properties box (CTRL-1), then do the same for the lines that you want the LTSCALE to be 30 on. Aside from that, you could create a linetype based on the different LTSCALEs (HIDDEN20 and HIDDEN30 for example. Hope this helps.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Different scales for lines in different viewports
    Have you played around with the PSLTSCALE variable?
    From Autocad help.
    Type: Integer
    Saved in: Drawing
    Initial value: 1
    Controls paper space linetype scaling.
    0 No special linetype scaling. Linetype dash lengths are based on the drawing units of the space (model or paper) in which the objects were created. Scaled by the global LTSCALE factor.
    1 Viewport scaling governs linetype scaling. If TILEMODE is set to 0, dash lengths are based on paper space drawing units, even for objects in model space. In this mode, viewports can have varying magnifications, yet display linetypes identically. For a specific linetype, the dash lengths of a line in a viewport are the same as the dash lengths of a line in paper space. You can still control the dash lengths with LTSCALE.
    When you change PSLTSCALE or use a command such as ZOOM with PSLTSCALE set to 1, objects in viewports are not automatically regenerated with the new linetype scale. Use the REGEN or REGENALL commands to update the linetype scales in each viewport.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2003-12
    5
    Smile Re: Different scales for lines in different viewports
    Thanks very much - I guess I will need to play around with this to see if I both understand it and can make it work.
    Suzy
    2003-12
    5
    Quote Originally Posted by jhohman
    I had thought about that but was hoping that I could get around duplicating lines. Thanks for the ideas.
    Suzy
    The Silent Type
    2015-08
    66
    1 members found this post helpful.
    definetly use psltscale set to 1. Set your global ltscale so the line looks correct in the viewports (not model space). Celtscale should be 1 (unless you need to override for a specific line). Autocad will adjuct the displayed line in each viewport so that all lines of a linetype look the same in your layout. You will have to adjust to the lines having a very small scale in model space. It looks odd at first but you get used to it.
    Chuck
    Active Member chadwickt's Avatar
    2015-12
    84
    I just played with this last week, and it works great!
    To build on what Chuck said a little bit:
    When I did this, everytime I changed the scale of a viewport I had to REGENALL in order to get all the viewports looking the same (this appeared to be a screen issue, as all the linetypes would print fine for me whether I regenerated or not)
    Chuck, does yours automatically regenerate when you change viewport scaling?
    13,621
    Quote Originally Posted by chadwickt
    Hi
    A RegenAll is automatically performed when a plot is successful ie The "OK" button is pressed.
    Have a good one, Mike
    2015-12
    84
    Thanks Mike...so it will automatically REGENALL when you actually click OK to print, but if you want to see it before then you must do a REGENALL...is this correct?
    13,621
    Hi
    Yes, that's about the sum of it.
  1. Multiple Viewports with Different Scales: Glitch??
    By Treed.255529 in forum AutoCAD Civil 3D - General
    Last Post: 2010-07-08, 04:40 PM
  2. Replies: 2
    Last Post: 2008-05-20, 01:18 PM
  3. 2 viewports with 2 different scales but same text
    By dutch724 in forum AutoCAD General
    Last Post: 2008-04-24, 10:28 PM
  4. Replies: 1
    Last Post: 2006-12-05, 04:00 PM
  5. Replies: 41
    Last Post: 2006-11-14, 08:38 PM
