Has anyone else had issues with the angle families? The bottom plane dosen't seem to be the bottom of the angle, the top dosen't seem to be the top. the center seem correct, but that's about it.
Can anyone tell me why on earth you would want the anaylitical centroid of an angle used as a reference plane for placement. How do you add this as a deck edge angle? Well one way is to put the angle in, cut a section, use the align tool, the use the align tool again. Then after you get that done, you need to go back and re-adjust the framing that it's attached to.
So then I tried the floor/slab edge/bent pl. The results there are just as disapointing.
