Thread: Beam coping questions
    Active Member bgarrett's Avatar
    2005-06
    Springfield MO
    54
    Question Beam coping questions
    I was wondering if anyone has figured out a way to add a radius to the coping function. This is similar to another post: http://forums.augi.com/showthread.php?t=43171&highlight=beam+coping+radius but the issue was not resolved. You really shouldn't show a square end on a cut for a cope because they might fabricate it that way.
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Somerville, MA
    291
    Default Re: Beam coping questions
    Brett,
    There is no way that I'm aware of to put an automatic radius on the cut but you can achieve the look you want for detailing by using the linework tool and adding some detail lines to your beam. See attached image.
    -ken
    Ken Marsh
    Owner, Marsh API
    2005-06
    Springfield MO
    54
    Ken,
    Thanks for the reply, I was just hoping there was a option some where that I was missing.
  1. Coping
    By douginwood in forum Revit Structure - General
    Last Post: 2015-11-04, 06:30 PM
  2. 2015: Can't Cope two beams error "coping applied but no cut was made. adjust coping ..."
    By vitolopes8699207 in forum Revit Structure - General
    Last Post: 2015-04-30, 02:13 PM
  3. Legends - how to show beam-beam & beam-col conn?
    By lcamara in forum Revit Structure - General
    Last Post: 2014-05-04, 10:45 PM
  4. Coping Beams (Beam-To-Beam)
    By sdijanovic1583519 in forum Revit Structure - General
    Last Post: 2011-09-25, 07:10 PM
  5. Beam Coping Tool ?
    By mbalsom in forum Revit Architecture - General
    Last Post: 2008-04-10, 02:42 PM
