I have quite a few different questions here all pertaining to ABS 2007. I am working with a Windows XP Prof operating system. If anyone has answers to these please reply. It may be helpful if you refer to the questions by number since there are quite a few here.
1) I need some help with ductwork manipulation. After a duct has been inserted in the drawing how can you find out if it was inserted with a center-center justification, or a bottom-center justification? How can you change that once it is already in the drawing? This will be necessary if we have one person working on a drawing and it gets passed off to another they use different justifications and the new ducts will from the plan view appear to be connecting, but in an isometric view you will see that they will be offset due to the justifications that were used to insert the ducts.
2) Is there a tee of some sort that will allow 3 different duct sizes and allow me to align the top part of the tee with both of the ducts? In other words it would not be going centerline to centerline, it would be left-justifying for the "top" portion of the "T".
3) Is there a way to get the duct flow and the piping flow arrows to show up larger? Most of the time they are exceptionally small, or I can't even tell if they are on the drawing at all. I select the duct, right click, and check the "show flow arrow".
4) Sometimes when I change a duct transition from concentric to eccentric it may or may not adjust in plan view, I have a hunch that it may be adjusting in the z direction, but when I go to isometric or side views that transition is now a line, not a 3D object. Why? How can I get this to show up properly? Is this some sort of display configuration issues? I have it set to MEP Design, and as far as I remember we have not tweaked the display config's (yet) for this issue.
5) How do I change the pipe fittings to automatically come in as say threaded instead of flanged fittings?
6) If you drop in a duct fitting in the middle of a duct to transition down to a different size, how do you get the duct label that standardly shows up in the duct to show up on the newly resized duct? The "duct label" icon outputs more information that what I am looking for, but the duct size label that automatically kicks out when ductwork is drawn is perfect.
Thank you in advance to anyone who is able to help with any of these issues! My company is jumping up from R14 and we have not had any training on how to utilize this program so I'm just winging my way through this.
