When I insert a block containing attributes from the tool palette it always opens the Edit Attributes dialog even though ATTDIA is set to 0. If I insert the same block using the insert command it prompts for attribute values at the command prompt.
Is there a way to get block tools on the tool palette to prompt for attribute values on the command line?
