Thread: AutoCAD 2005 message - unable to create sheet set file
    2005-03
    15
    Unhappy AutoCAD 2005 message - unable to create sheet set file
    Hi ,
    When I want to create a sheet set in AutoCAD 2005 I get a message that says
    " unable to create sheet set file".
    Help, anyone?
    Thank you,
    Drakir
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: AutoCAD 2005 message - unable to create sheet set file
    Could you provide a little bit more information on the steps you take during this process?
    13,656
    Hi
    Have a browse of the following couple of threads from the Autodesk Discussion Groups, they may offer some help / guidance...
    Cannot save sheet sets to mapped network drive!
    Setting up a sheet set template
    Have a good one, Mike
    2005-03
    15
    Unhappy Re: AutoCAD 2005 message - unable to create sheet set file
    Here are the details,
    I go file,new sheet set,and I use existing drawing ( I also used example sheet) , then when I get to- store sheet date file (.dst) here; and I browse to a location (any location, either on my hard drive or on the network) , then I get the message the fatal message,
    Unable to create sheet set file.
    I tried it on my co-workers station and they can create a sheet set file. (darn it!)
    thanks for the help,
    Drakir
  1. AutoCAD 2007 "Unable to create Sheet Set file"
    By jramos77 in forum AutoCAD Sheet Set Manager
    Last Post: 2008-05-29, 10:25 PM
  2. AutoCAD 2005 & 2007 unable to Plot to file
    By matt9882 in forum AutoCAD Plotting
    Last Post: 2007-02-14, 01:25 PM
  3. Replies: 10
    Last Post: 2007-02-07, 07:43 PM
  4. AutoCAD LT message - Unable to save to drawing...
    By briand.87290 in forum AutoCAD LT - General
    Last Post: 2005-12-13, 07:25 PM
