Thread: BATCH DRAWING CONVERTER save_as R14 in Read Only mode
    2004-06
    2
    Exclamation BATCH DRAWING CONVERTER save_as R14 in Read Only mode
    Hi, when I use BATCH DRAWING CONVERTER to save dwg from 2004 to R14, the files become in Read Only mode when opening with R14.
    There is no Check mark on Read-Only attribute properties (in Explorer).
    I have Windows XP.
    I didn't see any option in BATCH DRAWING CONVERTER or in Autocad for this issue.
    Is anyone know if it's a bug in BATCH DRAWING CONVERTER? If yes how to fix it?
    thanks
    Mustang
    2001-10
    Arizona
    2,337
    Default Re: BATCH DRAWING CONVERTER save_as R14 in Read Only mode
    Not knowing where you are opening these converted files from
    I offer this. If from a CD this is typical as most files written to CD
    do indicate that they are read only.
    If not take a look into this:
    ATRIB SYNTAX
    Displays or changes file attributes.
    ATTRIB [+R | -R] [+A | -A] [+S | -S] [+H | -H] [[drive:][path]filename] [/S]
    + Sets an attribute.
    - Clears an attribute.
    R Read-only file attribute.
    A Archive file attribute.
    S System file attribute.
    H Hidden file attribute.
    /S Processes files in all directories in the specified path.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2004-06
    2
    It's from my C: drive & the attributes are clear.
    I think that BATCH DRAWING CONVERTER program has a bug...
    Quote Originally Posted by mjfarrell
    ATRIB SYNTAX
  1. Batch DGN to DWG converter
    By invisible_guy in forum CAD Management - General
    Last Post: 2011-09-09, 07:54 PM
  2. Batch Text Converter Anyone?
    By mccurdyks in forum Revit Architecture - General
    Last Post: 2007-09-26, 06:40 PM
  3. Batch Converter
    By rjairath in forum AutoCAD Civil 3D - General
    Last Post: 2006-11-27, 04:26 PM
  4. Batch Drawing Converter
    By zfoland20 in forum AutoCAD General
    Last Post: 2005-05-09, 06:40 PM
