Thread: Importing Mastermap data into Map3D
    2004-10
    22
    Unhappy Importing Mastermap data into Map3D
    We use Map3D almost solely because of it's map importing function.
    However, the data doesn't display properly.
    I can use the same data in Arcmap (ESRI) and everything is there.
    I really need some help on this.
    I can supply data files if necessary.
    13,656
    Default Re: Importing Mastermap data into Map3D
    Hi "patricia.ellistone" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the ATP Course Wishlist forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2004-06
    123
    Your request is not complete enough to really get a grasp of what the problem is. I assume you are missing some entities that are not displaying at all. Is it a shape file, object data present, poly file?
    jim
  1. Import AutoCAD Map3D Object Data
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2014-11-13, 06:00 PM
  2. OS Mastermap
    By steve.medlock249376 in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2013-04-28, 07:59 PM
  3. Replies: 2
    Last Post: 2012-07-03, 08:12 PM
  4. OS Mastermap
    By cj624248 in forum AutoCAD Map 3D - General
    Last Post: 2011-07-02, 12:32 PM
  5. Importing Surface Data from LDT to C3D
    By jackland in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-06-17, 04:30 PM
