Similar to, or as an option of, the wish discussed in the thread "Section Region" like a Plan Region http://forums.augi.com/showthread.php?t=43374
We would like to define a hidden line region in section and elevation views in order to show a hidden line outline of objects that are obscured by walls in the elevation or section. For example, we have a two-story atrium with a balcony and a stair runs up through the balcony. We want to show hidden lines outlining the portion of the stair that passes behind and is obscured by the soffit wall of the balcony.
Being able to define a region that would show what is beyond while still showing the solid soffit wall would solve this problem.
Currently the workaround is to create a temporary section, trace the portion of the stair with hidden line drafting lines, and cut and paste aligned those hidden lines to the real section. Obviously this is tedious if you're showing anything of any complexity.
- Rusty
