Results 1 to 10 of 10
Thread: converting description keys from land to c3d
    2002-02
    4
    Cool How do i convert description keys from land to c3d?
    I already have description keys for my points in land already set up how do i bring them into civil 3D ?
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    Wink Re: converting description keys from land to c3d
    Try to import into your C3D template(s) using import from LDT Data in the File menu and only pick description keys in the list when it comes up.
    Earth
    9,804
    Default Re: converting description keys from land to c3d
    Quote Originally Posted by Christian Barrett
    Isn't this capability only in C3D 2007?
    glwrcddj, If this is C3D 2006 or earlier, you can use the services offered here
    R.K. McSwain | CAD Panacea |
    2006-01
    Temecula, CA
    281
    Well, I wouldn't know and did not consider any other version other than 07.
    Earth
    9,804
    Well, since the OP did not mention the version being considered, we'll just have to wait and see....
    2002-02
    4
    Thank you all for your input. The release i am using is 07
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    This is a rather involved process that I learned at CAD Camp. I have not done this yet myself so I will just give you abbreviated instructions from the handout.
    1. Insert all the symbol blocks to the prototype drawing.
    2. Create a point style for each description key. Set the marker, the block and point layers.
    3. Import the description keys. From the General pull-down in C3D select Import Data from Land Desktop. Select your project and uncheck everything except Description Keys.
    4. Associate each key to a point style.
    We saw a demo of Steltman software that did this whole process automatically. Not sure what the cost is though.
    Hope this helps.
    Earth
    9,804
    Quote Originally Posted by jpaulsen
    Jeff, as Christian mentioned in the first reply, C3D 2007 will do all this for you automatically.
    2002-04
    Colorado
    2,020
    That will get your description keys into your C3D prototype but you still need to go through the other steps to make them work. The symbols and layers are assigned in the C3D point style, not the description keys. At least that's what they told us at CAD Camp. They were using the 2007 version.
    Earth
    9,804
    You're right. My bad. I thought I had done this in 2007 and it did everything... I just tried it and you're right, it only sets up the description keys and the Point Style and Point Label Style are still set to <default>
    I wonder why Autodesk didn't finish this tool? Wouldn't have been very difficult...
    So I guess there is still a market for Robert Steltman's tool
  1. 2015: Description Keys not matching
    By todd.80290 in forum AutoCAD Civil 3D - General
    Last Post: 2015-03-19, 03:56 PM
  2. Description Keys
    By rlshound in forum AutoCAD Civil 3D - Survey
    Last Post: 2010-04-08, 12:06 PM
  3. Description Keys - LDD 2006
    By mpayne in forum AutoCAD Customization
    Last Post: 2007-09-26, 04:16 PM
