Results 1 to 6 of 6
Thread: Best software/method to use after scanning paper drawings for use as backgrounds?
    2004-03
    4
    Default Best software/method to use after scanning paper drawings for use as backgrounds?
    What is the best software and method to use after scanning existing paper drawings to use as backgrounds? I work for a HVAC contractor, we often get old building/ mech drawing we use for our base /xrefs. I use COREL to do some cleanup the image manager.
    What are other ideas?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default Re: Best software/method to use after scanning paper drawings for use as backgrounds?
    Quote Originally Posted by wcricple
    Usually, I simply insert a jpg or tiff file into an ACAD drawing. I also scale the image to the proper size so I can draw the other elements of the drawing to the right dimensions. Sometimes I'll use Photoshop to clean up or modify the image.
    Earth
    9,805
    What is the best software and method to use after scanning existing paper drawings to use as backgrounds? What are other ideas?
    We use Autodesk Raster Design.
    R.K. McSwain | CAD Panacea |
    13,656
    Hi "wcricple" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Hi
    If you have not looked at Scan2CAD, it is worth a look ( in my humble opinion )...
    Scan2CAD
    Have a good one, Mike
    2006-01
    Land of chocolate
    228
    I'm more used to handle photoshop (don't know coreldraw that well) for cleaning up graphic files.
    If you wanna edit the scan into your cad system - you'll need a raster software add-on.
    There are several products on the market, but we use WISEIMAGE - its pretty good, and low cost.
  1. Replies: 2
    Last Post: 2015-03-24, 02:28 PM
  2. Best way to edit paper based drawings with AutoCAD?
    By runarm673809 in forum AutoCAD General
    Last Post: 2012-08-24, 03:55 PM
  3. drawings wont stay in paper space when saved
    By acm_n_jlm102597 in forum AutoCAD General
    Last Post: 2012-01-05, 05:47 PM
  4. Creating Backgrounds for Mechanical Drawings
    By scottr.128732 in forum Display Management
    Last Post: 2006-12-08, 05:44 PM
