Thread: Semantic errors in DCL files
    2004-07
    9
    Default Semantic errors in DCL files
    Issue:
    I get a error message when opening a Cad drawing in 2004. The solution for Autodesk 2005 is good to know, but I am not sure if it applies to 2004. I had problems with my computer last week and when it was repaired the problem started.
    I receive the following errors when starting AutoCad
    autocad message "base.dcl" can't find file <OK>
    semantic errors in dcl file acadmap.dcl see file acad.dce for details<OK>
    semantic errors in dcl file ade.dcl see file acad.dce for details<OK>
    I can follow the steps listed in # 2 below but the lddt.arg file open in notepad does not resemble the sequence below.
    Any Thoughts
    Solution for Autodesk 2005
    The default Lddt.arg and the default Map.arg files reference the Windows user profile that was used for installation. When a different user account (with power user rights) logs on to the machine, by default this account will not have access to the original paths listed in the ARG files.
    If you have not run Land Desktop 2005 as a Power User, simply modify the "ACAD" path in the Lddt.arg file. Follow these steps:
    1. If you have not yet run Land Desktop 2005, in Notepad, open c:\Program Files\Land Desktop 2005\lddt.arg file and find the line beginning with the text "ACAD"=".
    2. Modify the following portion of this path as shown, replacing "C:\Documents and Settings\<user name>\" with "%USERPROFILE%".
    ORIGINAL TEXT: "ACAD"="C:\Documents and Settings\<user name>\Application Data\..."
    CORRECTED TEXT: "ACAD"="%USERPROFILE%\Application Data\..."
    3. Repeat for C:\Program Files\Land Desktop 2005\Map.arg.
    If you have already run Land Desktop 2005, you will need to follow the steps above, then delete the "Land Desktop" profile
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,259
    Question Re: Semantic errors in DCL files
    I'm sorry, but, just to clarify are you using AutoCAD 2004? or Land Desktop?
    Quote Originally Posted by wtrujillo
    Issue:
    Any Thoughts
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
  1. Semantic Error(s)
    By pzr27 in forum VBA/COM Interop
    Last Post: 2008-01-15, 06:56 PM
  2. Errors when loading linked files??
    By patricks in forum Revit - Platform
    Last Post: 2008-01-14, 08:22 PM
  3. Civil 3D 2006 Semantic error(s)
    By hunterhyde in forum AutoCAD Civil 3D - General
    Last Post: 2008-01-14, 06:31 PM
  4. Errors when creating DXF files (DXFOUT)
    By kens.73906 in forum AutoCAD General
    Last Post: 2004-08-27, 08:03 PM
