Anybody have a good slate roof shingle hatch pattern they are willing to share? I have looked online but have not been able to find anything
Thanks
Tim
Thanks
Tim
You may find a suitable shingle pattern amongst these links (for example in the Shakertown collection) :
http://www.cadro.com.au/hatchkit/HatLinks.html
Post a sketch if you're totally stuck.
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Actually...
Here...
417 patterns.
If a pattern doesn't work, open it in NOTEPAD, you will see that the cursor can go to the line below the last line of code, BACKSPACE to the end of the end of the last character on the last line and save. It should work then.
Is there a way to use any of these pat files as a model-typ hatch instead of a drafting-type?
John B
"With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
If you are referring to Revit, search your file system for the text file called Revit.pat. The comments at the head of that file explain how to set the pattern type.
Hugh Adamson
www.hatchkit.com.au
