Thread: using filter command
    2009-09
    32
    Default using filter command
    I want information about how to use logical operators AND, OR etc in the autocad filter command. Currently facing problems in using them. I searched google but could not find the material which explains this in a bit detail. Please provide some guide.
    For example Using filter I want to select entities which are not now a layer say layer 0. How to do this.
    First I add BEGIN NOT. Then add layer to the selection criteria. But as I do that BEGIN NOT goes below the layer name. I think BEGIN NOT and END NOT should enclose the layer name.
    Thanks.
    9,805
    Default Re: using filter command
    Have you examined the examples in HELP?
    http://docs.autodesk.com/ACD/2010/EN...0acaf-4b32.htm
    Yes, the logical operators need to enclose the other operands.
    2015-08
    Eastern Iowa
    87
    Quote Originally Posted by mdsalman2003 View Post
    Thanks.
    mdsalman2003-
    Why would you begin your search with Google? Wouldn't you use AutoCAD's help menu first? It will provide information on most of the basic and intermediate questions. Have you searched Autodesk's website for answers?
    Oh and an English grammar note: when asking a question, use this punctuation mark (?) - otherwise you are issuing a command, or your purpose becomes unclear. Here, in the forums,it is always better to ask for help then to demand answers.
    Good luck to you mdsalman2003!
    2015-11
    Jo'burg SA
    4,512
    The only way to modify the filter list is to select the one you want to change and click the sustitute button. Unfortunately there's no Move Up / Down buttons.
    Remember that if you click the Add to list button it places the new item in the selected position. Usually the selected position is the last (blank) item, but you can manually select the position by simply clicking inside the list box at the top.
  1. FILTER command less useful than it once was?
    By kmayhew936033 in forum AutoCAD General
    Last Post: 2010-09-20, 12:12 PM
  2. How to access Filter command through command line
    By sandeep_koodal in forum AutoCAD General
    Last Post: 2009-05-09, 07:19 AM
  3. command FILTER
    By aurel in forum AutoCAD Customization
    Last Post: 2009-04-23, 07:33 PM
  4. Filter command within CUI
    Last Post: 2005-10-31, 02:57 PM
  5. The FILTER command: using XOR
    By LanceMcHatton in forum AutoCAD General
    Last Post: 2005-01-06, 05:18 PM
