Results 1 to 6 of 6
Thread: Revit elements screened by Imported CAD dwg's
    2002-12
    12
    Default Revit elements screened by Imported CAD dwg's
    Is anyone else having a problem with imported AutoCAD drawings screening Revit elements. We use the arch. plan drawings as an underlay for our plan drawings, and change them to halftone in the visibility graphics. We have tried many different scenarios, and can't seem to solve this problem. Any suggestions?
    2002-02
    St. Louis, MO
    4,695
    Default Re: Revit elements screened by Imported CAD dwg's
    do you import them as a model element or a symbolic object?
    If as a symbolic object, do you have them set to foreground or background?
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    If you import to "current view only" you will be able to select whether you want the imported file in the foreground or the background. If you need it in other views just copy to clipboard and past aligned "same place".
    Joe
    2002-12
    12
    Thanks, we have tried that, but we use hidden view for upper levels, and the only time we can see the backgrounds is through holes in the slab (like at elevator openings, etc.). If we set it to foreground, it screens slab edges, columns, and walls.
    Revit Moderator Tom Weir's Avatar
    2003-11
    639
    Hi,
    Have you tried to add a separate level and import the arch. drawing there? Put the level well below your lowest building level. Then you can select that level as an underlay and it should show up.
    And believe me you are not the only one with this problem. We talk about it a lot. If you do a search in Revit Building General on this subject you might get some other ideas.
    Tom Weir
    Los Angeles
    I could stop if I wanted to FOUTJM's Avatar
    2005-12
    the island
    237
    select the imported instance and set its elevation to just above the slab.
  1. Replies: 3
    Last Post: 2009-08-07, 05:34 PM
  2. How to hide/show elements in a imported .dxf file
    By cveaels in forum Revit - API
    Last Post: 2008-09-26, 12:40 PM
  3. Wish: screened viewports
    By john.103073 in forum AutoCAD LT - Wish List
    Last Post: 2006-03-31, 04:18 PM
  4. screened porch
    By bbapties in forum Style Management
    Last Post: 2005-09-09, 05:06 PM
  5. Screened Porch
    By BCrouse in forum Style Management
    Last Post: 2004-07-15, 08:18 PM
