I do not want the border of the viewport to print when I plot the image. How can I remove the border of the viewports? Can this be done?
Thank you.
Thank you.
Place the outline for the view port on a unique layer,
then freeze, turn off, or set that layer as NO PLOT.
Hi
Check out the following thread -
Model space lines
Have a good one, Mike
Thanks for the assist. Works like a champ.
Make your viewports on defpoints layer. This layer does not have to be frozen, it is a non-plotable layer !
Putting anything on the DEFPOINTS layer is another topic altogether. I don't put anything on thayt layer and I don't recommend it. It's just as easy to create a seprate layer and make it non-plottable.Originally Posted by wcbates
When I was using r14, we'd put the viewport on a separate layer and then freeze that layer.
AutoCAD Civil3D 2013
Gig 'Em, Aggies!
Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
