Thread: Viewport Issue
    2003-03
    Question Viewport Issue
    I do not want the border of the viewport to print when I plot the image. How can I remove the border of the viewports? Can this be done?
    Thank you.
    2001-10
    Arizona
    2,337
    Default Re: Viewport Issue
    Place the outline for the view port on a unique layer,
    then freeze, turn off, or set that layer as NO PLOT.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    13,499
    Hi
    Check out the following thread -
    Model space lines
    Have a good one, Mike
    2003-03
    Thanks for the assist. Works like a champ.
    2004-06
    5
    Post Re: Viewport Issue
    Make your viewports on defpoints layer. This layer does not have to be frozen, it is a non-plotable layer !
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,233
    Quote Originally Posted by wcbates
    Putting anything on the DEFPOINTS layer is another topic altogether. I don't put anything on thayt layer and I don't recommend it. It's just as easy to create a seprate layer and make it non-plottable.
    When I was using r14, we'd put the viewport on a separate layer and then freeze that layer.
    AutoCAD Civil3D 2013
    Gig 'Em, Aggies!
    Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
  1. Replies: 13
    Last Post: 2011-09-10, 11:16 PM
  2. Titleblock - issue date and type of issue placed in issue column
    By jdrexler in forum CAD Management - General
    Last Post: 2006-04-10, 05:01 PM
  3. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
  4. Viewport Issue - Zoom Extents
    By Globey in forum AutoCAD General
    Last Post: 2005-11-07, 01:25 PM
  5. Viewport clipping issue
    By Spectrefish in forum AutoCAD General
    Last Post: 2004-09-30, 07:51 AM
