dkoch
I am not quite certain what you are trying to do with the profile, but the reason it will not let you pick both of the door panel rings you have drawn is that they touch each other. You do not need to draw the individual leaves; a single ring for the entire opening is sufficient. I stretched a copy of each of your door leaf rings away from the center by 0.01" so that they did not touch, and tried selecting the two door leaves first [not voids], then selecting the outer ring [as void] and finally the two glass rings [as voids]. ADT does not like void outer rings, and it is doing something very wierd with it - substituting that ring for the frame, perhaps??? [All modifications done in ADT 2004.]
The attached file has your original door, polylines & profile at the "right" and two of my attempts, at the left and center. The left effort is a copy of your polylines, without the individual door leaf polylines, and gives a result similar to what I would expect for a pair of glazed doors, but may not be what you want. The center effort is as described previously with the strectched door panels, with the bizzarre result.
Note also that since your polylines are not exactly 6'-0 wide x 7'-0" high, the profile will be scaled to fit in both height and width, throwing off the proportions of the original polylines.
