Thread: Color fill (Fill pattern) not updating
    I could stop if I wanted to tonyisenhoff's Avatar
    2003-07
    Milwaukee, Wisconsin
    424
    Default Color fill (Fill pattern) not updating
    I'm creating a color fill based on Occupancy... (no color, just fill patterns)
    When I make a change to my color fill legend (change to a different fill pattern), not all, but some rooms that should update don't. I have to go to those rooms, properties, select a different Occupancy, then back to the original, then the pattern updates.
    I tried "refresh" with no luck...
    In the attached imaged, all the rooms marked with an "X" are of the same Occupancy... You can see that some are showing the "Honey" pattern, while other rooms with the same occupancy are using the old pattern.
    Any suggestions?
    I could stop if I wanted to rodneyf's Avatar
    2003-05
    Charlotte, NC
    251
    Default Re: Color fill (Fill pattern) not updating
    Tony,
    Sorry I don't have an answer for you but I just wanted to add that I am getting the same thing with the actual color fills.
    Rodney Fiallo
    2005-07
    Somewhere in the BIM world
    3,139
    How about changing the color fill legen for something else, then back to the needed one ?
    That should be faster if it works.
    2005-12
    Philadelphia, PA
    225
    Unhappy Re: Color fill (Fill pattern) not updating
    Did anyone ever find a solution to this? I am having the same problem...
    Peter Vanko, Architect, LEED
    2005-12
    Philadelphia, PA
    225
    Smile Re: Color fill (Fill pattern) not updating
    I was able to duplicate the "changing of occupancy" to get the color fill to update. Of course, the occupancy has nothinig to do with the color fill legend (or, at least, not mine). To trick it into working even faster, just drop an un-enclosed area tag into the room and then quickly "undo." Color fills/hatches update immediately.
    It's just a bug...simple as that.
    Last edited by petervanko182254; 2006-10-23 at 07:21 PM. Reason: Found a work-around...
  1. Fill pattern
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2010-11-05, 02:10 PM
  2. Fill pattern
    By bgauthier in forum Revit Architecture - General
    Last Post: 2007-03-07, 02:32 PM
  3. Room Color pattern fill
    By wynand in forum Revit Architecture - General
    Last Post: 2007-02-17, 04:13 PM
  4. Color Fills & Color Fill Legends
    By Allen Lacy in forum Revit Architecture - General
    Last Post: 2003-10-02, 03:13 PM
