jmessner
OK, here is a situation that may not be all that likely, but can happen. I started setting everything up for an addendum to the "Bid Set" (Revision schedule, clouds tags, ect.) we'll after realizing that there wasn't going to be enough time to get the drawing to all of the subs before the bid date we decided to take care of the major things in written form that where really going to affect the bid. (the drawing was minor things) Anyway being that I have only worked on Revit a few months I didn't think threw the process first...... I had already made Revision 1 as the "Addendum 1" and Revision 2 as "Construction Set" (the changes that are/were taking place between the "Bid Set" and "Construction Set"). Not thinking threw the process I combined the Revisions of the "Addendum 1" with the "Construction Set" because I wasn't going to issue them is this addendum 1 but rather in the construction set later on. So when I did that I realized that my construction set that was #2 now goes to #1 well I still want to keep track of the addendum's is this project so I undo and do it the other way around and then add another so they are in the right order. Now where ever I had the drawings clouded with the addendum 1 stuff (which should now be #2 construction set) it is still showing Addendum #1 on the schedule along with the Construction Set. Question is how do I get rid of that Addendum #1 on the title blocks?
