Results 1 to 10 of 12
Thread: Can these Specs be better???
    All AUGI, all the time Les Therrien's Avatar
    2003-05
    Tecumseh, Canada
    623
    Question Can these Specs be better???
    My current computer system has been upgraded many times so this time around I think it's time for an all new computer again. I was talking to my tech and this is what I'm looking at. Please tell me what you think and let me know if there's any areas I could improve on.
    Part of the reason for an all new system is to prepare for the someday upcoming Windows Vista. So a 64 bit computer it will be.
    Intel Core2 Duo E6700 2.66GHz (possibly X6800-2.93GHz)
    4 GB RAM (later to be expandable to 8Gigs after the release of Vista)
    ATI Radeon x1400 (or higher - how much is overkill???)
    250GB HD (7200RPM)
    Win XP Pro & R9.1
    Now I know that currently Windows does not take advantage of the 4Gigs of RAM. It maxs out at 3.25 or so. In the rendering benchmark thread, this seems to be a problem with clay_hickling's computer!? Should I max out at 2Gigs and upgrade later???
    Any help would be greatly appreciated so I can get this ordered and get back up to speed.
    I could stop if I wanted to funkman's Avatar
    2003-07
    Sydney, Australia
    437
    Default Re: Can these Specs be better???
    Quote Originally Posted by Les Therrien
    I have win64. The only regret I have is that I didn't employ a dual boot operating system which would have allowed a choice of startup in xp or xp64. I would be running revit in xp, the others in xp64. Eveything else works fine in xp64. I have also 4gb of ram.
    ...and then the barman said, "now we can all get some sleep!"
    2003-05
    Tecumseh, Canada
    623
    Are you saying that Revit not stable in the Win64 environment?
    2003-07
    Sydney, Australia
    437
    No not at all - revit is totally fine on my computer. I have been using it now for over a year. In fact the benchmark test results shows I was around 3rd or 4th at the time even with RAID5 slowing it down. The only problem is the display of thumbnails in explorer which doesn't work - the latest I heard is that the factory is working on a fix.
    I use Leonid's thumbnail explorer now which he provided a fix for x64 in only a day or two. You would think that Revit could do it even faster, but until more x64 systems infiltrate the market, I don't think they look at it seriously.
    HTH
    2003-05
    Tecumseh, Canada
    623
    Great thanks!
    So I'll stick with building the 64bit system with 4Gigs of RAM.
    This may be a dumb question but, what is Raid?
    I've heard this term many times. Even my tech has mentioned it before. But he is a computer science wiz and sometimes the conversations are way beyond me!
    2003-07
    Sydney, Australia
    437
    no worries mate. I actually learn't all my limited knowledge from Irusun who I think posted this link regarding Raid. It can get very involved, but does make sense. Have a coffee and read.
    RAID - CLICK HERE
    In a dash, there is more than just one hard drive depending on your chosen raid configuration, and if one hard drive happens to die, it allows you to replace the drive without losing any information as it rebuilds the lost data from the other drive/s.
    2003-05
    Tecumseh, Canada
    623
    thanks Funkman!
    So back to the thread title. Because there's been little response, I'll assume that they're good.
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,343
    They're not good; they're very good. That CPU is the sweet spot of the Core 2 lineup: good value and performance. And the ATI cards will serve you well. That box will eat most other computers' breakfast
    Wes Macaulay LEED AP
    Teck Construction LLP
    Revit 2014 x64 | Win7 x64 | nVidia GT 650M
    Tell Adesk what you think!
    2003-05
    Tecumseh, Canada
    623
    Thumbs up Re: Can these Specs be better???
    Thanks Wes.
    That's all I needed to hear.
    2003-05
    Tecumseh, Canada
    623
    Question Re: Can these Specs be better???
    So this is what I'm looking at specifically spec. wise. Can anyone see anything here that is conflicting with Revit????
    Intel Core2 Duo E6700 2.67GHz
    Asus P5B-E main board
    Apacer 4GB RAM (1x4) DDR2 800 (PC2 6400) memory
    ATI X1600 512M Video PCI-E x16 Dual output
    250GB HD (7200RPM)
    Win XP Pro. 64Bit Edition & Revit 9.1
    Front & Read mount USB ports
    DVD Writer x16 Lightscribe
    CD writer x52
    Western Digital 250G SATA2 16M 7200rpm Hard drive x2 Raid 0 Stripping Black Mid Tower front USB & sound with light, side vent. 650W Power Supply 24pin Sony 1.44M floppy Case fan XP Pro 64 bit License and CD
    Western Digital 320G hard drive in external Enclosure
  1. Hardware Specs
    By Scott Tyler in forum Revit Architecture - General
    Last Post: 2009-08-28, 09:03 PM
  2. e-SPECS for Revit
    By bcgatti in forum Revit Architecture - General
    Last Post: 2009-03-18, 12:11 AM
  3. What are the best rendering specs to use?
    By gbelous in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-09-16, 01:50 PM
  4. Anyone using or tried E-Specs for Revit?
    By sjsl in forum Revit Architecture - General
    Last Post: 2004-10-02, 06:57 PM
  5. E-SPECS
    By luigi in forum Revit Architecture - General
    Last Post: 2004-06-18, 04:46 PM
