Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: Maxwell is out for ArchiCAD
  1. #21
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Maxwell is out for ArchiCAD
    Nice work Taylor. Could you share the file so i can get it in Max and vray and compare ?
    Obviously with the help of Dwayne
    Also what kind of hardware are you working with (for comparison purpose)
    If the file is too big to email i can set you up on our FTP
    email me at daniel.hurtubise@@lemaymichaud.com
  2. #22
    I could stop if I wanted to dellis's Avatar
    2003-12
    Windsor, Ontario, Canada
    379
    Taylor,
    Thats a pretty cool design. I agree about personal preference as far as software goes....but i would rather not wait around for long render times....which is why i use VRay Seriously though...radiosity isn't really a good method to use for exterior scenes. Not sure if you used the newer adaptive subdivision capabilities in the newer versions of radiosity in MAX/VIZ....this would help bring the render times down....as well as the type of image samplers/filters you may be using for anti-aliasing.
    What are your machine specs that you used for that image? Any chance you would let me render that thing in VRay?
    Dwayne D. Ellis
  3. #23
    2003-12
    379
    DOH! A little slow on the draw!!
    Dwayne D. Ellis
  4. #24
    100 Club tbarnesarc's Avatar
    2004-07
    Laguna Beach, CA
    186
    Quote Originally Posted by dellis
    Taylor,
    Dwayne D. Ellis
    Radioosity or not. The rendering times in Viz w/ scanline are a lot longer. Like I have said, I have never used Vray. I was just comaparing Viz on it's own. That's a lot of money to spend for Viz and Vray, when I can get good fast results out of Modo that costs $850. That was my main point. I will look for the file and hand it off to you guys. PM message with both your emails and I will send the file to you.
  5. #25
    I could stop if I wanted to rmejia's Avatar
    2006-10
    Puerto Rico
    432
    Nice house ! Is it going to be built as in the renderings ? My first thought was "only in California" then I see your location "CA". California has the most interesting architecture for me, I wish it would spread everywhere else.
    I gave up on scanline, it is the slowest ever. Viz and Max also come with Mental Ray which is a powerful renderer. The nice thing about viz is the file link and hopefully it will be more compatible with revit in the future because it's Autodesk, but who knows. That could be 15 years from now (Viz 2022) (Revit 24)
  6. #26
    2003-12
    379
    I agree...buying MAX/Viz/Vray does cost alot. I would say that MAX costs too much for sure....but you can do quitre a bit with that combo. It really depends on what you use the software for....for me....i need MAX and all of its capabilities, as well as VRay....although like i said before mental ray is pretty cool now too!!!
    Hey Taylor...do you use imagesynth too? It looks like an amazing tool. ZBrush has something similar...not for $99 though!!!
  7. #27
    2004-07
    Laguna Beach, CA
    186
    Here is the link to the file if anyone wants it. It is in FBX form because I lost the original Viz fail due to a hard drive crash. It should work with anything: DH FBX
  8. #28
    2003-12
    379
    It was crashing both MAX 8 and 9. I updated the fbx plugin and it goes through the import but nothing comes in.
  9. #29
    2006-10
    Puerto Rico
    432
    Same problem here with Viz2007, it crashes when it gets to the mesh convert part. Downloaded an Autodesk FBX converter, but it also crashes when trying to convert to .3ds
    http://usa.autodesk.com/adsk/servlet...112&id=8309270
  10. #30
    2004-07
    Laguna Beach, CA
    186
    What form works for you then? I can re export. OBJ maybe?
  1. Maxwell 1.1
    By narlee in forum Revit - Rendering
    Last Post: 2006-07-11, 02:01 PM
  2. Maxwell FYI
    By sjsl in forum Revit - Rendering
    Last Post: 2005-08-29, 07:43 PM
  3. Maxwell vs Viz
    By philipnoland in forum Revit - Rendering
    Last Post: 2005-06-08, 07:16 PM
  4. Maxwell vs Viz
    By philipnoland in forum Revit Architecture - General
