Thread: Repeat the last command by hitting a single key
    Default Repeat the last command by hitting a single key
    Based on the title of my inquiry, you can tell I am a new user to AutoCAD and presently enrolled in the CAD Certificate program at Purdue to learn the program properly. My question is when I am repeating an object such as a line or circle or any other command, I would like the option of hitting a single key, such as a function key, which will repeat the last command without having to resort to a toolbar repeatedly. Another application for this option would be the use of AutoCAD in measuring linear or square feet of space. Any help would be appreciated. Thank You, JAD.
    All AUGI, all the time Richard.Kent's Avatar
    Albuquerque, NM, USA
    1 members found this post helpful.
    Default Re: Repeat the last command by hitting a single key
    Hit the space bar or the enter key, or the right mouse button (may have to set up as enter in customization).
    VDC Manager Brian Myers's Avatar
    St Louis, Missouri
    Kent's solution is the right answer, I've been using the spacebar for over 17 years...many others the right click. Also, Welcome to AUGI!
    Brian Myers
    Virtual Design and Construction Manager | BIM Manager | Author
    LinkedIn Profile
    AUGI Addict Railrose's Avatar
    Abilene, TX
    You can also use multiple before a command to make it repeat. I create a command alias of mu for it.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
  1. 2014: how to repeat FILLET command
    By rchalmers in forum AutoCAD Customization
    Last Post: 2014-06-02, 01:08 PM
  2. Repeat Last Command
    By gmg in forum Revit - Platform
    Last Post: 2013-04-20, 10:29 PM
  3. Repeat last command
    By Revit Wishes in forum Revit Architecture - Wish List
    Last Post: 2013-01-04, 05:39 PM
  4. Command alias repeat on the command line
    By rbilger in forum AutoCAD General
    Last Post: 2011-08-18, 09:47 PM
  5. repeat command
    By Ning Zhou in forum Revit Architecture - General
    Last Post: 2009-12-14, 07:59 PM
