Results 1 to 7 of 7
Thread: Opening multiple drawings in a single session of Land Desktop 2007 (SDI)
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    Default Opening multiple drawings in a single session of Land Desktop 2007 (SDI)
    There are several post regarding this subject on the forum. Some with obscure titles. Hopefully this post will be easier to find and will answer everyone's questions.
    There is information in the Autodesk knowledge base on the subject. Please refer to document ID: TS1057006.
    Jeff Paulsen
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Opening multiple drawings in a single session of Land Desktop 2007 (SDI)
    That KB article doesn't seem right. Opening files using the standard Open command does not work correctly. Neither does using the Drawing History. And I have yet to figure out how to open drawings using the External Reference manager...
    I've been playing with SDI.
    You can set SDI to 1, and then you can use the File History and Sheet Set Manager to switch between drawings. Unfortunately, the Land Desktop Open and New commands will only work when SDI is 0.
    So, it is possible to switch this setting as needed. For example, if you are working in a given project all afternoon and want to be able to move around by using the Sheet Set Manager, you can set SDI to 1. You just need to set it back to 0 in order to use Open or New, or any of the other commands that require SDI=0 (such as PUBLISH).
    Unfortunately, switching SDI between 1 and 0 all the time can get rather confusing. It is NOT a very good solution. But it's an option that may make life in 2007 slightly easier.
    I STILL keep hoping Autodesk will release an SP that fixes this issue, but I'm losing hope...
    2002-04
    Colorado
    1,901
    Sinc,
    You are correct. They goofed again. I read thought it pretty quick and didn't notice the error.
    Th KB states "There are several other ways you can open multiple documents in Land Desktop 2007 without encountering this issue:"
    It should read something like "There are several other ways you can open multiple documents in Land Desktop 2007 that cause this issue."
    I wouldn't give up hope yet on SP2. I've heard it will be out this Friday (fingers crossed).
    Jeff Paulsen
    2002-04
    Colorado
    1,901
    I have installed the Land Desktop Companion service pack 2 and almost all of these issues seem to be resolved.
    Previously it was possible (very easy) to have a drawing from one project open and be accessing data from another project. Now it is much more difficult. I ran many tests and was not able to access the wrong project using SSM, drawing recovery, history list, double clicking a drawing in explorer, drag and drop from explorer or the AutoCAD open command.
    It is still possible to access the wrong project data but it is much more difficult.
    If you open multiple drawings and close all but one and the drawing you keep open is from a different project than the first drawing you opened you will be accessing the wrong project.
    I also saw an intermittent problem when opening an xref through the xref manager but it was very difficult to reproduce consistently. I would say 3 out of 30 times the project changed when I opened a drawing this way.
    One last thing to look out for. Creating a New drawing from the zero drawing state randomly assigns a project to the new drawing. I would recommend using the AECNEW command instead of AutoCAD's NEW or QNEW commands to avoid this problem.
    Jeff Paulsen
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,381
    One of the FIRST things I did after installation, was to set the Overrides to use AEC Dialogs when working in Land.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2004-02
    Colorado
    1,986
    Quote Originally Posted by jpaulsen
    Evidently SP2 has been pulled due to serious instability problems reported by many users...
    Hopefully they'll get it straightened out soon.
    2002-04
    Colorado
    1,901
    I hope so. Apparently some users are experiencing lockups.
    I haven't used LDT too much since I installed SP2 but I would guess I have about 4 hours logged on it with no lockups.
    Jeff Paulsen
  1. Opening Multiple Drawings on Autocad Land Desktop 2009
    By ebhram in forum AutoCAD Land Desktop - General
    Last Post: 2009-06-09, 10:54 AM
  2. Managing Multiple drawings in a single session
    By jhohman in forum AutoCAD Tips & Tricks
    Last Post: 2006-12-21, 08:37 PM
  3. AutoCAD LT 2006 - Opening multiple drawings within same session
    By lazer2go in forum AutoCAD LT - General
    Last Post: 2006-11-30, 09:00 PM
  4. Replies: 5
    Last Post: 2006-10-09, 09:25 PM
  5. opening drawings in land desktop
    By 348PATTERSON in forum AutoCAD Land Desktop - Wish List (Closed)
    Last Post: 2005-09-22, 11:11 PM
