Results 1 to 7 of 7
Thread: Cutting Precast Geometry
    Member mshilderbrand's Avatar
    2005-05
    4
    Default Cutting Precast Geometry
    I have a precast double tee protruding into a core wall. I need to cut the geometry in 2 directions. I set up my reference plane but can only seem to cut the geometry once.
    Also, is there a way to dapp the double tee legs where they hit the L beam seat with RS?
    Sorry for the noob question, this is my 2nd day on RS.
    100 Club Scott Hammond's Avatar
    2005-09
    128
    Default Re: Cutting Precast Geometry
    You can use the "Coping" tool where the precast double tees meat the L-beam.
    Scott Hammond
    AEC Marketing Manager - Civil & Structural Engineering
    Autodesk, Inc.
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Waltham, MA
    254
    Here's a cool trick (thanks to Phil Palmer et al for this one)
    1. make a new column family that is a simple solid extrusion
    2. set it's material to the same material as the precast (you may need to transfer project standards into your new column family to have the material available (File>transfer project standards...)
    3. place it in the project to be a "cutter" object, (where the corner of your precast double t should be removed
    4. join geometry between cutter column and precast double t
    5. create a new filter
    5a. go to VG
    5b. select filters
    5c. click filters...
    5d. click new...
    5e. give your filter a name and choose "define criteria"
    5f. select "structural columns"
    5g. Filter by family name = name of your cutter column family
    5h. click ok, then select this filter and 'ok' in filters dialog
    5i. click "insert" in VG/filters tab, select your new filter.
    6. Turn off visibility for this filter
    7. now you have a "hole"
    Hopefully there will be an easier way to do this in future releases.
    Have fun!
    -Ken
    Ken Marsh
    Member Terry Jordan's Avatar
    2003-12
    Fulton, Illinois
    43
    Thanks for the great tip, Ken!
    I would like to add that, if you give your cutter column a Visibility parameter you can skip the filter and just "turn off" the column. This way it is automatically invisible in all views and you won't need to filter it in all views.
    To turn the cutter column back "on", you would then need to select it in the project browser, right click and pick "select all instances", select properties and change it's visibility which might be a pain if you have multiple instances. I guess you could just copy and rename the cutter columns for each instance.
    My 2 cents...
    Terry Jordan
    Structural Designer | BIM Manager
    Shoemaker & Haaland Professional Engineers
    Coralville, Iowa
    100 Club lzaras's Avatar
    2001-03
    118
    Ken Marsh's post, with the work-around from Phil Palmer was posted back in 2006.
    Are there any updates? How are you handling cutting back your precast double tees around walls?
    Leanne
    AutoCAD 2010 Certified Professional
    Revit Architecture 2012 Certified Professional
    Charlotte, NC
    RST2010 / RST2011 / RST2012 / RST2013 / ADT2006 / ACA2010 / ACA2013
    2007-01
    181
    try using the opening by face tool. located on the home tab.
    2013-03
    Opening by face! yes!
  1. FLOOR CUTTING WALL GEOMETRY
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2010-07-26, 08:20 PM
  2. Cutting Geometry Issue
    By richard.carlisle in forum Revit - Platform
    Last Post: 2008-12-29, 05:41 PM
  3. Door geometry not cutting
    By patricks in forum Revit Architecture - Families
    Last Post: 2006-11-04, 06:41 PM
  4. Plan Representation not Cutting Geometry
    By ctc in forum Revit Architecture - Families
    Last Post: 2006-05-02, 04:04 AM
  5. Geometry cutting in sink family won't work...
    By gnl in forum Revit Architecture - Families
    Last Post: 2004-01-22, 09:34 PM
