Thread: cant crop raster image on sheet
    2003-10
    Santa Barbara
    397
    Default cant crop raster image on sheet
    I have a raster image of a survey I want to put on a sheet but it is larger than the sheet so the poprtion hanging over the title block throuws the plot layout off. I would like to put it in a detail view and place it on a sheet but there are no crop regions for a detail view. any suggestions?
    2005-08
    73
    Default Re: cant crop raster image on sheet
    How I usually handle this is create a duplicate plan view and place the image I'm importing on the new view and crop it as needed. Then you can drag it onto the correct sheet.
    I could stop if I wanted to jspartz's Avatar
    2015-12
    361
    Sometimes with a really busy plan duplicating it and using the crop regions will leave a ton of tags that you have to right click on and hide annotation in view. The other way would be to put an elevation marker on the plan, shrink the elevation box to practically nothing, then hide that annotation. Then you can put the image in your elevation, turn on the crop region, and only have to hide your level markers if they are within the crop box.
  1. No Raster Image in PDF
    By wayne.peterson in forum Raster Design - General
    Last Post: 2010-08-23, 11:13 AM
  2. ECW Image Crop?
    By cosmojr in forum Raster Design - General
    Last Post: 2010-04-30, 04:58 PM
  3. Crop Image?
    By mdemint in forum Impression - General
    Last Post: 2009-09-28, 08:35 PM
  4. image crop
    By rstiles in forum Raster Design - General
    Last Post: 2008-03-19, 03:58 PM
  5. crop raster images?
    By jessica.146534 in forum Revit Architecture - General
    Last Post: 2007-11-30, 09:00 PM
