If you look at the attached PDF you will see a sub from a button. When clicked the button will iterate through items in a ListView control and place text in the drawing. This is were the problem starts. The sub executes fine until it hits lines 410. The an error is thrown and I get an error message (see attached Err.png).
I can't see what I'm doing wrong. The code is basically copied and pasted from other source and it worked fine there. Can somebody help?
