I have a drawing that I need to rotate the whole model 90 degrees so the attribute X & Y values are positive numbers. When I do such part of the X & Y insertion points are positive and some are negative values yet they ALL are in the positive quadrant. This makes absolutely no sense why I am getting negative values. I am also wondering if there is a variable that would allow me to extract attribute values that are tied into a UCS rather than the world UCS. Using EATTEXT whenever I extract attributes they are tied to the WCS. I have attached the BAD drawing along with a small XLS file of what I get when I use the EATTEXT command. Thank you for any and all help.
