Thread: Update / Add data in linked Excel Sheets so it automatically updates in AutoCAD
    2005-05
    111
    Question Update / Add data in linked Excel Sheets so it automatically updates in AutoCAD
    I am using Autocad 2006. When I paste an Excel doc. in Autocad It puts in in as an ole object. When I link it I can change the source file. But if I add a new roll to the spread sheet Autocad does not update the table to show the added line it cuts it off.
    Is there any way to have Autocad Update the area it looks at in excel???
    Dynamic Blockhead Mod Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Re: Update / Add data in linked Excel Sheets so it automatically updates in AutoCAD
    Quote Originally Posted by pangell
    reinsert it and make sure to change the sheet size in your excel file from a 8.5x11 to a custom size of 20x40 or whatever the largest size is ....
    conversely, you COULD copy it and paste special as an AutoCAD object to have the spreadsheet transferred into AutoCAD as part of the drawing ....
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2001-03
    13,499
    Hi
    Take a look at THIS thread.
    Plus, have a browse through the following thread, found in the AutoCAD FAQ (Read only) forum...
    Working with OLE (eg Excel) Objects within a drawing file
    Have a good one, Mike
    125
    I recently had to link some excel sheets into AutoCAD 2005 and when I did such I pasted a few extra blank rows. I placed it into modelspace and then I created a PS viewport just to show the data. I scaled it to 1=1 and the text size was fine. I then sized the viewport to show only the lines of data that were filled in. If I had to add or delete a line in the spreadsheet I would go into the drawing and stretch the viewport so it only showed rows with data. Not a prefect fix but until one comes along I figured this was kind of easy to do.
  1. Data linked Excel table formatting
    By georgen in forum AutoCAD General
    Last Post: 2011-09-09, 02:23 PM
  2. 2011: suppress zeros in data linked excel table
    By ccowgill in forum AutoCAD General
    Last Post: 2011-06-14, 05:16 PM
  3. Fields linked to Excel Data
    By g_wong in forum AutoCAD Fields
    Last Post: 2009-11-10, 05:37 PM
  4. Replies: 3
    Last Post: 2006-11-30, 04:30 PM
  5. Creating points from Excel Data sheets
    By todd.mackay in forum AutoLISP
    Last Post: 2005-01-19, 06:27 PM
