Results 1 to 10 of 14
Thread: Keep Text Objects plan readable as a rotate parameter is used
    2005-03
    Utah
    31
    Question Keep Text Objects plan readable as a rotate parameter is used
    I am having trouble with creating a dynamic block. Basically what I am trying to do is keep annotation objects plan readable as a rotate parameter is used. I have tried using linked rotate parameters, but instead of keeping the annotation at an angle zero, it rotates at twice the rotation of the block when using the primary parameter. This kind of makes sense, but is there some way to 'reverse' the angle of the secondary parameter?
    Dynamic Blockhead Mod Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Re: Keep Text Objects plan readable as a rotate parameter is used
    Quote Originally Posted by eyokom
    if you couls post the file I'm sure we could figure it out faster than guessing .... there's like 3 or 4 things it could be ....
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2001-03
    13,499
    Hi "eyokom" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2005-06
    1,828
    Talking Re: Keep Text Objects plan readable as a rotate parameter is used
    Quote Originally Posted by CAD cowboy
    thanks for posting the file ...
    I'm having a bit of a hard time figuring out what you want the block to do .....
    Do you want the text to stay on a 0 degree plane? I think that's what you're asking (in fact I'm pretty sure of that) and so I've modified your block to do just that.
    Let me know if this is not right and I'll try to help some more .....
    [SIGPIC][/SIGPIC]
    2005-03
    Utah
    31
    Thumbs up Re: Keep Text Objects plan readable as a rotate parameter is used
    Thanks Max,
    That was exactly what I was trying to accomplish. I knew that I was overlooking something. Obviously just couldn't remember exactly what the right parameter to use was. I appreciate the help.
    2005-06
    1,828
    Thanks Max,
    Anytime, buckeroo. anytime.
    [SIGPIC][/SIGPIC]
    2011-05
    Hello - I would like similar help with door labels created in AutoCAD. I have the width as text in the block, but would like to keep it readable when the block is rotated. I've attached the dwg w/block. Thanks
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by mark_chavez398480 View Post
    did you look at the 'fixed' block above to see what was done? iirc, the text is attached to a point parameter that is chained to the rotate parameter...
    S&D DB Sharing Forum
    2009-06
    4
    I'm trying to use the example above to do something so similar that I'm frustrated that I cannot get it to work. I must admit that I haven't got the hang of chaining actions and that may be part of my problem. How do you know what comes first?
    I want to create a block with 6+ attributes that will keep a readable angle when the block is rotated. I'm pretty much at ground zero since I can't figure out how to make the actions chain or even work properly. From what I gleaned in the block above: point parameters are used on the text with a Move action. Then a rotate function grabs them all. How does the zero rotation of the text occur? How does the alignment of the text maintain? How does it link together?
    If I understood the "order of operations" I think I'd be ok. Any pointers would be much appreciated.
    Thanks
    I could stop if I wanted to clshade's Avatar
    2009-01
    B5
    465
    I've attached a DynBlk that has several to look at.
    I would suggest that you post your attempt and lets look at it.
    Most times the issue is easier to find that way and better guidance can be offered.
    Charles Shade LT 2013
    www.cshadedesign.com
  1. 2011: complex linetype plan readable
    By gandocadguy in forum AutoCAD General
    Last Post: 2010-08-17, 12:00 PM
  2. Make Attribute Text Plan Readable?
    By mdemint in forum Dynamic Blocks - Technical
    Last Post: 2010-02-05, 08:01 PM
  3. AutoCAD 2009 Proxy objects not readable in 2007
    By Mamma Jamma in forum AutoCAD General
    Last Post: 2009-12-28, 11:30 PM
  4. READABLE TEXT
    By ford347 in forum Revit Architecture - General
    Last Post: 2005-08-15, 06:24 AM
