Thread: Only able to select one Object at a time
    2006-03
    Gods Country, Iowa
    3
    Question Only able to select one Object at a time
    I pulled up a drawing from another architectural firm and from the time I did it my selection box began picking only one line at a time. If I want to delete, say 3 lines, the only way to do it is to hold down the shift key and pick the three lines. The process previously was automatic, pick lines as you want them, right click to delete.
    I know there is probaly a menu to change that someplace but I can't find it.
    HELP
    Craig
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Only able to select one Object at a time
    Hi,
    Under Options, on the Selection Tab, make sure Use Shift to Add to Selection isn't checked.
    Edit: BTW, welcome to AUGI.
    Tim Creary
    S&D
    DILLIGAF
    2006-03
    Gods Country, Iowa
    3
    Smile Re: Only able to select one Object at a time
    Nothing better than a fast answer to a problem.
    It worked. I don't know how it got set that way but your answer was correct and welcomed.
    Thanks
    Craig
    Lost
    1,473
    You're welcome. Have a good one.
    Tim Creary
    S&D
    DILLIGAF
  1. Can select only one object at a time
    By Capt. Computer Crasher in forum AutoCAD General
    Last Post: 2008-04-03, 01:58 PM
  2. How can I select last object
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-04-07, 05:41 PM
  3. Replies: 0
    Last Post: 2005-07-08, 11:27 PM
  4. Trim command, only able to select one line at a time
    By sherflor in forum AutoCAD General
    Last Post: 2005-05-10, 07:34 PM
  5. Replies: 3
    Last Post: 2004-06-14, 06:50 PM
