Hi all,
I can't find a problem WHY?
I create master plan.rvt for central file. In option user name i user to be change to Master. This file have grid and column. Next i close master plan file and check box in Make this the Central file.
Next i want to make Architect building. I change the username to Team A in option. And open the Central file is master plan.rvt. Create new workset is Architect for active. And draw some wall. I save as to Architect.rvt And save to Central file. It work Central file it update.
But i change to other CPU open revit change username to Team B. Open Master plan.rvt it the Central file. It been up to date from Architect. Revit have 2 warning about it cannot connect with central file. I check file path pass network it true can i connect CPU to CPU. When i try to create new name workset to Interior and active. Save as to Interior.rvt it can. Save to Central file CANNOT.
WHY? WHERE I WRONG?
