Problem
My assy's require more then one sheet to display the required detail information. The BM is placed on the first sheet with different ipn views on the following sheets. When you hide and renumber the BM on sheet one, the following sheets have non-matching numbers in the item balloons. The current result is to over ride the item numbers with the correct ones. This is a pain in the butt. Is there a better way or is the fix in the next release.
Thanks to the one who has a good solution for this.
Scott
