Results 1 to 10 of 11
Thread: Civil 3D 2007 - Wipeout does not wipeout Objects in a floating viewport
    2006-02
    19
    Angry Civil 3D 2007 - Wipeout does not wipeout Objects in a floating viewport
    I have a wipeout that I need to place over a viewport.. when it is placed over something in paperspace it works fine.. but when I move it to the viewport it does not wipeout anything at all.. I even tried to draw it over the viewport area and do a draworder.. but the things in the viewport still appear..
    13,656
    Default Re: Civil 3D 2007 - Wipeout does not wipeout Objects in a floating viewport
    Hi "wolvezbane" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD 2007 3D forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2006-02
    19
    **BUMP**
    Still having this problem.. text in paper space... build Wipeout to hide behind text... everything appears in model space... draw order does not fix it... texttofront does not fix it... Wipeout in paperspace... model space shows through it!! all settings put at the proper numbers.
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    Can you use textmask out of the express tools? Does it have the same problem? Have you opened the dwg in any other version of Autocad to see if it works then?
    2006-02
    19
    Negative.. text mask does not work...
    Also tried to do it on 3 other machines using normal Autocad 2007
    the results are exactly the same....
    2006-01
    Temecula, CA
    281
    I can't seem to reproduce the problem and I can't think of what the problem may be. I know a couple of work arounds, but I assume you want a fix not a work around.
    2006-02
    19
    It only seems to be a recurring problem for one certain job.
    all of that jobs drawings seem to have this problem. No matter what machine or version of autocad is being used.
    100 Club MMccall.83699's Avatar
    2005-03
    a little off center
    140
    Check your page setup. In the plot option section there's a check box to plot the paperspace objects last, which puts them on top of the viewport/model space items. If the box is already checked, uncheck it, exit the page setup, then go back and check it again.
    2006-02
    19
    That is currently not the problem.
    I am attaching one of the files from that job.
    Please go ahead and create a wipeout.. in paperspace.. over a view port and you will see what is happening.. if it does it for you.
    Also if you do the wipeout in the viewport in "model space" the exact opposite happens... everything in Paperspace disapears... even though the wipeout is in model space
    2005-03
    a little off center
    140
    I'm using 06 so I had to convert your file. I also blew up using a wipeout. However, I was able to get the same result you've described using MText with a background mask. Then I checked the page setup. The check box for plotting paperspace last was not checked. I checked it and the problem went away. Try this on your system.
    The attached pic shows it working.
  1. Wipeout to Ignore Certain Objects
    Last Post: 2010-03-15, 01:39 PM
  2. See and Apply Properties to Objects Behind a Wipeout
    Last Post: 2009-01-13, 04:31 PM
  3. AutoCAD sometimes prints objects under a Wipeout...
    By lconnolly in forum AutoCAD Plotting
    Last Post: 2006-07-28, 02:27 PM
  4. Plotting Wipeout objects from Paperspace
    By jonathan_fairholm in forum AutoCAD General
    Last Post: 2004-11-11, 04:37 PM
  5. Pasting objects over a wipeout object
    By fenlandhippie in forum AutoCAD General
    Last Post: 2004-11-10, 10:07 PM
