Thread: Trying to use a Block to ExTrim to
    2015-12
    385
    Question Trying to use a Block to ExTrim to
    Hey everyone,
    I am trying to use a block to extrim to. I would like to trim the same side as mi insertion point. Can anyone give me an idea on why this is not woirking?
    Thank all,
    Andre
    (defun c:locktrim ()
      (setq currlay (getvar "Clayer"))
      (setq lockpt1 (getpoint "\nSelect Daves Mid-cross: "))
      (setvar "Clayer" "Hardware")
      (command "-layer" "make" "0" "lock" "panels" "")
      (command "-insert" "lomountextrusiontrim" lockpt1 "1" "1" "0")
      (command "explode" "last")
      (c:extrim "last" lockpt1)
      (command "-insert" "lomountpaneltrim" lockpt1 "1" "1" "0")
      (princ))
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Last edited by Opie; 2006-10-24 at 06:56 PM. Reason: [CODE] tags added, see Moderator Action
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Default Re: Trying to use a Block to ExTrim to
    c:extrim will not accept arguments.
    What are trying to do exactly, so someone can help you.
    A picture please.
    2003-09
    31
    When at the command line you type (c:extrim) AutoCAD returns:
    Pick a POLYLINE, LINE, CIRCLE, ARC, ELLIPSE, IMAGE or TEXT for cutting edge...
    From this line you learn that you cannot give a block as parameter.
    You need to select one or more elements (from the list above) inside the block to extrim to.
    Correction:
    You can only select one element from the block at a time.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Why use c:extrim when you can use the built in AutoCAD EXTEND or TRIM Command ?
    : ) Happy Computing !
    kennet
    2015-12
    385
    Smile Re: Trying to use a Block to ExTrim to
    Hopefully this is a better explanation;
    I am trying to;
    lock layer "Panels"
    insert a block of a polyline
    explode that polyline
    use that polyline for an extrim object
    (for which side to trim on) use the same side of the polyline as my pickpoint
    erase that polyline
    unlock layer panels
    ;;;repeat part1 with a different block
    attached is a dwg which gives a better example.
    I have also made a buttoin that works close to what I am trying to accomplish,
    The button command txt is in this dwg
    Thank you all again soon
  1. Extrim
    By z_ayri788300 in forum AutoLISP
    Last Post: 2013-01-16, 12:38 PM
  2. EXTRIM to work in block editor
    Last Post: 2008-06-10, 02:24 PM
  3. Error using EXTRIM command
    By jason.cyr13 in forum AutoCAD General
    Last Post: 2007-12-03, 08:45 PM
  4. extrim - how it works?
    By inner69923 in forum AutoLISP
    Last Post: 2004-10-26, 08:56 AM
  5. extrim in vb
    By inner69923 in forum VBA/COM Interop
    Last Post: 2004-10-06, 04:17 AM
