Results 1 to 6 of 6
Thread: Cad Test
    2006-01
    8
    Default Cad Test
    Hello all,
    Just wondering what might be involved in an Autocad 2006 test from a commercial construction firm.? Im scheduled to take one but not sure what to expect. Im familar with ADT 2006 but thats it. Thank you very much
    Neal
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Default Re: Cad Test
    Think about the main parts of what you are expected to do at a job. It involves all sorts of things. Expect random trick questions.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2002-09
    Madison, WI
    4,440
    File management and use of standards and templates. Depending on the firm, I'm going to guess that they already have a large library of blocks and templates for you to use so I'd think creation may not be the big thing, but knowing how to start a drawing correctly is key. This tends to be one of the things that seperates the men from the boys (so to speak). One that can take a look at a large building and conceptually think of a plan on how to set up the files based on a company standard or can at least create a cartoon set with file names that sort correctly. If you can be productive in ADT, I don't think you should have much of a problem with plain CAD but what do I know. We just got done "fixing" what our supposed Cad Coordinator did when he set up the project. You would not believe how bad things were screwed up. Just my 2 cents.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-01
    8
    Thank you Steve, David.
    Its an entry-level position so maybe they'll go easy. Im not that proficient in ADT but do know how to get around. I'll concentrate on your suggestions, if any other helpful suggestions come to mind, that would be very sweet, thank you again.
    Neal
    2002-09
    Madison, WI
    4,440
    Neil, At an entry level, I'd say as long as you have the basics down I'd say you're ok. Lines, arcs, circles and x-refs'. Layer management could also be key. Just some thoughts. Good Luck!
    Dave Peterson
    2006-01
    8
    Thanks again David, I appreciate your input, and all others that chimed in.
    Neal
  1. test
    By sandrews.253556 in forum New Forum Users (Non technical)
    Last Post: 2011-01-13, 08:26 PM
  2. Test
    By Dinochrome in forum New Forum Users (Non technical)
    Last Post: 2010-11-19, 02:15 AM
  3. 3D DWF, can you test this for me?
    By schrodingerscat in forum Revit MEP - General
    Last Post: 2009-02-13, 01:13 AM
